Differential Install
Old Feb 2, 2006 | 03:33 PM
smittydog's Avatar
smittydog
Default Differential Install
I purchased a differential with 4:10s from a fellow forum member and will be installing this weekend. I've looked over the clutch install that Dope put up and it looks like a PIA but doable. My question is can I leave the tunnel plate, torque tube, clutch and tranny in place and remove the cradle, half shafts, brakes and differential while holding up the tranny and clutch with a jack? Thanks for the tips as usual!
Old Feb 2, 2006 | 06:21 PM
94legaleagle's Avatar
94legaleagle
No, you can't - I just finished a rear carrier swap on my A4 - but the shaft that comes out the rear of the tranny and goes into the rear carrier is about 12 inches long - there isn't enough room to slide the rear carrier back and off of this shaft UNLESS you lower the tranny and torque tube assembly down; HOWEVER, it ISN'T that bad of a job, and if you start Friday night, you should be done by Sunday night.
Here is a link: http://www.cajundude.com/differential.htm
Go to that link, print off EVERYTHING and follow it RELIGIOUSLY!!!! Cajundude makes it simple, trust me, I followed his advice exactly and it worked.
One thing to add to Cajundude's write up, is that there are TWO (2) tabs/do-hicky's that hold the brake lines to the cradle on EACH side. They are tough to see, but you need to get the brake lines out from under these.
Again, Follow CAJUNDUDE's instructions EXACTLY, and it is EASY!!!
Good luck!!
Old Feb 2, 2006 | 06:23 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I just put 4.10s in my car. You will have to
Jack up the car level on jackstand/blocks atleast 18" high
Take the rear wheels off
Take the rear calipers off and hang them aside
Undo the top bolts on rear shocks
Take the bolts off the upper control arms
Undo the Ebrake brackets
Pul out the half shafts
Take the catback off
Take the exhaust midsection off
Take the tunnel plate off (no going around this. This needs to be taken off but you dont have to disconnect the torque tube)
Undo the bolts on the cradle while supporting it with a bike jack
Put a jack underneath the tranny to support it
Take the ABS lines off the cradle and lower the cradle down
Separte the rearend from the transmission
I think that about it
Goodluck
Old Feb 2, 2006 | 06:25 PM
Roadrace65's Avatar
Roadrace65
I put my 3.90 diff in my FRC a couple weeks ago. You’re going to have to drop the tunnel cover to allow the drive line to tilt down far enough to get the diff off the tranny output shaft. Don’t forget to take the shifter **** and boot off. Loosen the air bridge clamp. I hung the calipers on big zip ties.
Low Gears Rock!!!
Old Feb 2, 2006 | 06:30 PM
Roadrace65's Avatar
Roadrace65
Goodluck
I usually:
leave the shocks on the car - disconnect the bottom
un-hook the ebrake cable and unclip
Old Feb 2, 2006 | 07:04 PM
Mike Mercury's Avatar
Mike Mercury
Old Feb 2, 2006 | 07:09 PM
Rhode Warrior's Avatar
Rhode Warrior
Low Gears Rock!!!
Been there done that. Just did my TC. Lots of fun.
Old Feb 2, 2006 | 07:38 PM
Roadrace65's Avatar
Roadrace65
Low Gears Rock
My FRC with LG's, Light Flywheel and 3.90's tore the paint off a C6 today on the highway
Old Feb 2, 2006 | 10:03 PM
smittydog's Avatar
smittydog
Thanks for the help! I'll be wrenching as soon as I get home from work and can't wait to burn up some tires!
Old Feb 2, 2006 | 10:11 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Low Gears Rock!!!
Old Feb 2, 2006 | 11:13 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Actually you can do it without removing everything. You just need to lower the tranny until the torque tube is about 1/4 inch away from the tunnel plate. Remove "I think the left side of the diff. Rotate the removed side up and slide it on. Done it plenty of times. Kaley
Old Feb 3, 2006 | 02:51 AM
Jserman's Avatar
Jserman
I hope you enjoy the gears as much as I did.......
let me know when you get everything all done and how much you like them..
Old Feb 3, 2006 | 07:50 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Cool info!!
Old Feb 3, 2006 | 08:28 AM
Mikelly's Avatar
Mikelly
Looking at those jackstands makes my back ache... Love my AAMCO twin post lift.
And heed that pic MIke Mercury posted. you WILL hit the firewall and crack it or the intake if you don't put a jack *(use a piece of wood between the jack and the pan) under the oil pan.
I've had my drivetrain out about oh, six or seven times now... Get an alignment after you put it all back together. Your centerline in the rear will likely be off and the car won't track properly.
Don't ask how I know...
Mike
Old Feb 3, 2006 | 09:56 PM
smittydog's Avatar
smittydog
I printed out Cajun Dudes Tutorial and bought plenty of beer. I'll be on it tomorrow and we'll see how long it takes me!
Old Feb 3, 2006 | 11:42 PM
0Kaley@DragonRace
Supporting Vendor
Did you get my post? By leaving the exhaust and the tunnel plate on it will take a few hours off of your instal time. If you need any help with the explaination you can give me a call. 970 567 2713. Kaley
Old Feb 4, 2006 | 10:18 AM
Roadrace65's Avatar
Roadrace65
I can see taking the side cover off for removal, but don’t like the idea of handling a new diff open to contamination at installation….JMO
To Differential Install
Old Feb 4, 2006 | 10:25 AM
90droptopp's Avatar
90droptopp
From: Murrieta Ca..... America, fun while it lasted
It takes you a few hours to remove the exhaust and tunnel plate......... there this new thing called air tools.
Old Feb 4, 2006 | 10:42 AM
Mikelly's Avatar
Mikelly
Not to mention the potential for screwing up the shim on the gears or preload on the pinion by a novice not used to such things...
Mike
Old Feb 5, 2006 | 04:12 AM
smittydog's Avatar
smittydog
Thanks for all the advice and tips. I had to take off my exhaust anyway for a couple of leak repairs so I went ahead and pulled the tunnel plate. I spent a couple hours cleaning the cradle and tranny before I put the new differential in and still ended up at about 8 hours. Not to bad for my first time and the best part was I didn't have to wait for break in cause the gears I picked up already had a couple thousand miles on em. It's a blast to drive and I'll be needing some street slicks soon especially for first and second to go with the perma-grin!
