Pulling car under lift and bent mast can I replace mast and if yes how. If I have to replace entire assembly how do you do that anyone have pictures or write up
KRL,
I am assuming you have a power antenna. Take out the passenger side tail lights. It's easy just a couple of nuts and wire connectors. Antenna assembly will come out through the taillight opening. I bought a used assembly form Gene at genekarshop.com, he's a supporting Corvette forum member. Should be able to find his web site on left hand side of this site. Good luck.
KRL,
Thanks and yes I have power antenna, can just the mast be replaced or do you replace assembly?
my mast was bent and the antenna would not go down, I figured I'm not going to play with trying to replace the mast when I can get a whole new antenna for less than $100.00!
