Kenne Bell Boost-a-Pump install questions???
Old Feb 3, 2006 | 06:43 PM
Fastbasser's Avatar
Fastbasser
Default Kenne Bell Boost-a-Pump install questions???
Gentlemen,
I need some info/suggestions on the install of a Kenne Bell Boost-a-pump on an 03' Z06 with a mild cam, headers, and A&A Procharger. Did a search and found and old thread but the photos were gone.
It looks pretty straight forward but figured if someone did it before and may have some insight/hindsight would speed the process. (and hopefully eliminate some of my errors)
The questions I have are as follows:
Where to mount the box?
Where to mount the switch/dial?
Where to tap the red/hot wire into?
A good initial setting (0-50) for the control? I would imagine then
that some dyno tuning would be in order to dial-in the correct AFR.
Anything else I should know to keep me out of trouble?
Thanks in advance for the assist!
Old Feb 3, 2006 | 08:08 PM
muncie21's Avatar
muncie21
Try this thread: BAP Thread 1 for starters
Old Feb 3, 2006 | 11:53 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I mounted mine in the rear driver's side fenderwell area.
Old Feb 4, 2006 | 12:38 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
OK, here is the stupid question of the week......although i have a good educated guess can somebody please tell me exactly what a boost a pump is in LAYMEN'S TERMS!!!!!!
Old Feb 4, 2006 | 03:01 AM
redbob's Avatar
redbob
It boosts the voltage to the fuel pump during wot for higher gph output.
Old Feb 4, 2006 | 08:21 AM
Mopar Jimmy
St. Jude Donor '06
THANK YOU!
Old Feb 4, 2006 | 10:06 AM
78Vette-SA's Avatar
78Vette-SA
Default One more question if you please...
Where have you mounted (tied in) the boost/vacuum switch? Again, I can assume there is a preferred location. (or at least a place of least "install resistance")
Pics would be great.
Thanks again guys!
Old Feb 4, 2006 | 10:23 AM
muncie21's Avatar
muncie21
Not familiar with your SC setup (I have a Maggie) but the vacuum line from the brake booster is generally a good start, if you don't have a dedicated port on the SC setup.
Old Feb 4, 2006 | 07:41 PM
Mike04's Avatar
Mike04
Here is a link to my thread on the same question. If you look in my pictures you can see the controller and "box" mounted next to the battery. Andy told me to set the dial to about 3/4s. I tapped into the brake booster line for vacuum. My BOV, Boost a Pump, and Boost gauge are all tapped in there.
http://forums.corvetteforum.com/show....php?t=1284198
Old Feb 4, 2006 | 11:13 PM
LeMansBlue04's Avatar
LeMansBlue04
I had one done for my 402 at 21st CMC. I also had them install the Racetronix harness. This harness takes voltage directly from the alternator to the fuel pump. It has an inline relay inside the rear fender well. The fuel circuit in the car activates this relay. The harness comes with adapters that allow you to plug the boost-a-pump into it. The boost-a-pump is mounted inside the wheel well against the bulkhead.
They mounted a throttle position sensor down close to the PCM to activate the BAP at WOT. Its a very clean setup and 21st did a perfect job. It all looks like it was wired at the factory.
Old Feb 4, 2006 | 11:35 PM
78Vette-SA's Avatar
78Vette-SA
Here's my dumb question. I understand where everything goes, but if the BAP is installed inline/across the Fuel Pump fuse, then all current goes to the BAP then to the Fuel Pump. The vacuum switch supplied has 2 spades that connect to the wire off of the BAP. Is this an on/off type of switch or does it increase output based on increased vacuum?
Is there any jiuce going through the BAP to the Fuel Pump at start-up/idle (obviously there has to be right)? And does the vacuum just increase that voltage? I didn't run any tests yet or put a voltmeter on it but was curious how the Fuel Pump gets power if nothing goes across the BAP until the boost reaches a certain level.
My guess would be that the BAP also supplies around 12v until the boost vacuum increases which in turn causes the voltage to increase above 12v up to 17.5v
Old Feb 5, 2006 | 12:11 AM
muncie21's Avatar
muncie21
You are partially right...or partially wrong..
BAP increases voltage to the fuel pump, it isn't proportional to the vacuum of the engine. The pressure switch is an on/off signal for the BAP to engage. The amount of boost (voltage) supplied is controlled by the rheostat (sp?) that comes with the BAP. Hope this makes sense..
Old Feb 5, 2006 | 04:59 AM
Dr. Dan's Avatar
Dr. Dan
Oh, the joys of a FFS fuel system...GM's better idea.
The folks at LPE told me to remove the rheostat and solder the wires together. The Vacuum switch will then give you full power to the pump only when needed and there's not a threat of running lean while you get it dialed in. Done it for 2 years now and keep 59 lbs on the gauge all the time.
Old Feb 5, 2006 | 08:15 AM
78Vette-SA's Avatar
78Vette-SA
To Kenne Bell Boost-a-Pump install questions???
