Gears????
Old Feb 5, 2006 | 01:11 AM
idiedtrying's Avatar
idiedtrying
Default Gears????
i want 4.10 gears, can you change just the gears and not the whoile diff?? where can i get a set from?? is it hard to do once the diff is out?
Old Feb 5, 2006 | 02:13 AM
Face's Avatar
Face
Search, this is covered a few times a week.
Old Feb 5, 2006 | 02:34 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Originally Posted by idiedtrying
I ALREADY DID.. all i found out was that some gears fit in some diff's....
now my ? is....
CAN I PUT 4.10 GEARS IN MY 97 AUTO WITHOUT CHANGING THE DIFF?????????????????????????
Calm down dude.....
What gears do you have currently? 2.73 or 3.15? It could be done though. I dont know why you'd wanna put 4.10s with A4 though
Old Feb 5, 2006 | 02:50 AM
Halfway's Avatar
Halfway
St. Jude Donor '06
You can put 4.10's in a diff that came with 3.42's stock(mn6), but you have to find a place that knows what they are doing.
Keep yelling at people to, you will get far with that.
Old Feb 5, 2006 | 04:40 PM
idiedtrying
ok thanks... i appreciate it. what would be good to put in my 97 auto? would it be worth the money you think?
Old Feb 5, 2006 | 04:51 PM
Face's Avatar
Face
I did.
If I drove the car every day, or drove long distances on the parkway often, it would drive me crazy. But for the occation trip to Jersey or the east end, it doesn't bother me.
Old Feb 5, 2006 | 05:17 PM
FactoryRaceCar
I would do 3.42 with a bigger stall on an A4. Or maybe maybe 3.73
Old Feb 5, 2006 | 07:32 PM
C6this's Avatar
C6this
Where can you get the 4.10's from? How much does it cost to have installed? I have a Z06.
Old Feb 5, 2006 | 08:48 PM
Face's Avatar
Face
ECS installed them. www.eastcoastsupercharging.com
Old Feb 5, 2006 | 09:06 PM
msuc5vette's Avatar
msuc5vette
Be careful who you chose to do the swap, it is not as straight forward as most rear end gear swaps.
It is worth the money to have one of the supporting vendors do the job and get it done right.
Old Feb 5, 2006 | 10:09 PM
Mike Mercury's Avatar
Mike Mercury
Old Feb 6, 2006 | 10:57 PM
idiedtrying
i checked on my diff. and it has 3.15 gears.. is that stock for a 97 auto?
Old Feb 7, 2006 | 01:22 AM
Iron Maiden Fan's Avatar
Iron Maiden Fan
Yes, that is stock. It's actually the performance gear ratio. You're choice of gears/stall would depend on your goals. 3.42's are great gears and work well with a decent stall. 3.73 are better, but you might face traction problems.
Do you drive on the freeway alot, or take trips? Are you going to use forced induction, nitros, or heads/cam?
Consider your future mods so you don't end up with more gear than you need to achieve your goals. It's an expensive mod, so plan well.
Old Feb 7, 2006 | 05:04 AM
blktie8's Avatar
blktie8
I've changed the gears twice started with 3.15 to 3.42 and now 3.73
I WILL STAY HERE ,BUT if it was a forced induction 3.42 would be best
If a 427 is the goal 373 with Rodney's Transmission and a Vigilante converter would be my choice
Old Feb 7, 2006 | 07:58 PM
idiedtrying
i have a plate kit NOS 125 shot now... im on 17" drag radials also... havent raced with the radials yet so i dont know if i will spin..also i dont drive it on the highway very often... and i will be getting QA1 shocks all the way around..
Old Feb 7, 2006 | 09:35 PM
Darkness's Avatar
Darkness
Without much highway driving I would definitely do the 3.73's.
Old Feb 7, 2006 | 10:08 PM
Face's Avatar
Face
Since you're spraying, 3.73's would be a good choice.
Old Feb 7, 2006 | 11:12 PM
idiedtrying
thanks everybody
To Gears????
