Header Question: Help!
Old Feb 5, 2006 | 11:57 PM
SBA Guy's Avatar
SBA Guy
Default Header Question: Help!
Hello-
My question is this: My friend ordered a set of Belanger headers for his 2004 Z-06 Corvette. He has upgraded to a C6, and will sell them to me. Does anyone know if these will have the proper fit to bolt on to a 02 C5 Convertible? It is a MN6 Z51 Car with Corsa Pace Car already on.
Thank you in advance-
Aaron
Old Feb 6, 2006 | 12:28 AM
turboc5's Avatar
turboc5
Should not be a problem. the only diffrences I know of from 2000 to 2001 they changed the A.I.R. tube location. If they are off of a 2004 they should not be a problem. However I'm not fimular with that perticular headder. If it uses the stock H pipe, and if the 02 to 04 are diffrent that may give you trouble. I know they chanded the mid section a couple of times over the years. But if it has its own mid section it should bolt right up
Old Feb 6, 2006 | 12:19 PM
SBA Guy's Avatar
SBA Guy
Thank you. I have a Corsa "X" pipe along with my Corsa Pace Car exhaust so I assume it would hook right into that as I a lot of people use this set up to link up to exhaust.
To Header Question: Help!
