Calling Paint experts...removing scratches
Good luck!
My Torch Red was damaged by a dealer when it was almost new. Someone laid something on the hood while it was parked inside the shop over night and then slid it off. The dealer's body shop wetsanded the entire hood and it looked like new.
I figured I might as well stay up and do it, because I probaly could not sleep from the stress. By the way, the cover is now my new jet ski cover.
Good luck!
Forget that, That stuff is awful. And Do not use a real buffer unless you have experience using one. USE the orbital. Want you want is 3m rubbing compound then 3m polishing.About $45.00 per qt. If they are too bad
Doesn't sound like they are. you can use carefully 2000 grit.
These products cannot be beat.
I would reccomend a 3M product called finnesse. Its white, bottle color veries though, but it could be applied by hand with great results with light surface scratches
Will even if it catches your nail, Be real slow and careful, Wiping often
with a towel. It will show very dull but You will see whats left of the scratch. Some clear coats are thicker than you think.
I once had a tenant. I booted out (meth head).
He came and keyed my car.(black) I called my agent.Got a check
Took it to the body shop. I mean this looked horrible.
Body looked close and saw the white in the scratch and said try this.
I spent $100.00 and went to work for over 10 hrs.By hand. The damage
came out and I had the best paint town, Just super super Gloss.
People knew it was me by the shine of the car
