Stock Torque converter Stall?????
Feb 8, 2006 | 11:03 PM
Cruise-In III Veteran
What is the Stall on a stock C5 torque converter? Anybody Know?????
Feb 9, 2006 | 07:29 AM
Feb 9, 2006 | 08:01 AM
I was thinking 1600, somewhere between 1300 and 1800 for sure.
Shane
Feb 9, 2006 | 09:13 AM
Feb 9, 2006 | 11:01 AM
Since I am new at this could someone explain why a higher stall torque converter is needed? What does is to for performance?
thanks,
Mike
Feb 9, 2006 | 11:30 AM
Stock stall is about 1,600. If your car is stock, you don't need a high stall. If you go with a cam, you need to match the stall to the RPM range that is best for your setup. A high stall converter also increases the torque of your car.
Feb 9, 2006 | 03:31 PM
Quote:
Yes you don't NEED one, but it still can make a night and day difference. I had a 4000 stall with stock internals, check my sig for #'s.
Feb 9, 2006 | 03:34 PM
Quote:
Those numbers are amazing for stock.
Feb 9, 2006 | 05:11 PM
1600
