Ls7 Engine On Special
Old Feb 9, 2006 | 12:07 PM
CorvettePartsBob's Avatar
CorvettePartsBob
Default Ls7 Engine On Special
This is Bob at Fichtner Chevrolet,
We just received another LS7 engine and have it available first come first serve for $ 14995.00 SHIPPED . To order give us a call at 800-234-5284
Bob
GM Performance Parts 427ci / 505hp ''LS7'' Engine
GM Powertrain, using valuable data gleaned from the factory-sponsored Corvette C5R racing program, developed the LS7 with many competition-derived components and design features. It takes production small-block performance to an unprecedented level while demonstrating the continuing adaptability of the engine's compact, cam-in-block design. It is, quite simply, the largest, most powerful production small-block V-8 GM has ever produced.
Specifications:
505 horsepower @ 6200 rpm
475 lb.-ft. of torque @ 4800 rpm
7000-rpm redline
Unique engine block with larger 4.125-inch bores and pressed-in cylinder liners
Forged steel crankshaft with 4-inch stroke
Titanium connecting rods
Cast aluminum flat-top pistons
Racing-derived CNC-ported aluminum cylinder heads with titanium intake valves and sodium-filled exhaust valves
Dry-sump oiling system (does not include lines or tank)
11.0:1 compression ratio
Camshaft with .591-inch lift
Hydroformed exhaust headers with unique quad flow collector flanges
Each engine assembled by hand by a single, specially-trained builder
