cam update
Old Feb 11, 2006 | 08:17 AM
Blow Torch's Avatar
Blow Torch
Default cam update
After reading a post in the performance section, I thought I'd through this idea out there to see if anyone has done it;
I'm changing to the Dart heads, and am going to change out a bad pulley, along with the chain and pump. Since I will be very close anyway, I haved toyed with the idea of changing grom my 224/224-268/268 cam to the mamo 224/228 cam. In reality, would this change really make enough difference to make it worth while?
I'm not interested in going any larger cams, just heard some good #s on this cam in the past.
Old Feb 11, 2006 | 05:58 PM
Blow Torch's Avatar
Blow Torch
Anyone???
Old Feb 11, 2006 | 06:07 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Thats what I did...swapped out my 220/220 to the 224/228 cam. I didnt peak much higher but my torque curve is so much better. and its still behaves almost like a stock cam at idle which is what I wanted the most.
Old Feb 11, 2006 | 09:17 PM
Silver98's Avatar
Silver98
On what lsa?
To cam update
