Adjusting rockers
Old Feb 12, 2006 | 08:12 AM
9T3JIM's Avatar
9T3JIM
Default Adjusting rockers
When switching heads on a LS1 how do you know if you are at TDC so you can tighten down the rocker arms? I remember on my 93 there was an arrow on the crank pulley that indicated you were there and you went through a sequence of adjusting certain rockers then rotate the crank and adjust the remaining rockers. Thanks for you're help!
Old Feb 12, 2006 | 09:41 AM
jers98vet's Avatar
jers98vet
LS1's are non adjustable from factory. I believe they are torqued to 22 foot pounds and thats it. When switching heads and or cams the adjustment is made by going with different sized pushrods.
Old Feb 12, 2006 | 09:51 AM
vettenuts's Avatar
vettenuts
I use a boroscope, but when the intake valve closes you can put a finger over the spark plug hole and wait for the air to stop.
To install the rockers, you need to have the #1 piston at TDC then tighten as follows:
Install and torque rocker arms at exhaust 1,2,7,8 & intake 1,3,4,5 to 22 lb-ft
Rotate the crank 360 degrees then:
Install and torque rocker arms at exhaust 3,4,5,6 & intake 2,6,7,8 to 22 lb-ft
Old Feb 12, 2006 | 10:12 AM
9T3JIM's Avatar
9T3JIM
Thanks guys, its coming back to me now!
To Adjusting rockers
