Upgrading FRC questions
So far I have come up with the following - seeking feedback. Anything big that I am missing? Are these numbers realistic? This will be for a non-raced street car and I am not sure the LG cam is the right move. Also, how important is the Z exhaust? I'm thinking this is the least important of the below parts. Thanks!
$1,000 Used LT Headers
$600 Used LS6 heads with upgraded springs
$300 Cam - LG Motorsports G5X3
$150 Used underdrive pulley
$300 Used LS6 intake manifold
$500 Used Z06 Ti exhaust
$1,000 Install
$500 Tune
$4,350 total
1)borla stingers quad tips
2)Lg LT headers
3)UD pulleys
4)Intake
5)cartek x2 H/C setup
this will be going on a 99 FRC too
this should be over 400 Rwhp
$1,000 Install
$500 Tune
$4,350 total
$1,000 for a set of used LG LT's is pretty inexpensive. Be prepared to pay a little more.
I think the G5X3 is ~$400 new, if you can find one used, then $300 would be a good price for it.
I would NOT buy a used underdrive pulley. They are stretched when pressed on and a used one WILL spin on a h/c car if the crank is not pinned.
$500 for a used TI exhaust is high, you should pay less than that for a mint set.
$600 for used LS6 heads with upgraded springs is optimisitc. I think you will be ~$1,000. I would buy used LS6 heads, clean them up and put NEW dual springs on if doing a cam the size of a G5X3.
As said above and supported by the fact that you can wrench, I would suggest you keep the $1000 for the install and do it yourself. These cars are pretty easy to work on if you do it step by step and take your time.
I also think $500 is a little high for a tune. Also, don't forget about gaskets and fluids.
Good luck and hope to see you on the forum soon.
$600 for heads is wishful thinking if you factor in the type of valve required by a GX3 cam.
Mark
