Changing Rotors
Old Feb 13, 2006 | 05:26 PM
Paul4137's Avatar
Paul4137
Default Changing Rotors
This maybe a stupid question. To remove rotors you just remove the caliper brackets? The two large bolts they are 13/16 standard not sure metric size the pull off 2 locks on studs and rotors slide off correct? Thanks
Old Feb 13, 2006 | 06:31 PM
RR02Vette's Avatar
RR02Vette
Default yes
You are correct. I did my rotor change this past weekend and it looks awesome!!
Old Feb 13, 2006 | 06:56 PM
Darion's Avatar
Darion
Yup and remember to disconnect the E-brake on the rear.
Old Feb 13, 2006 | 07:00 PM
rws.1's Avatar
rws.1
Yes,
The rear rotors have the e-brake shoes mounted inside.
The bolts are torqued at 125 ft-lbs and have red threadlocker on them so they are hard to remove.. without a breaker bar.
To remove the old rotor, you may need to beat on the back of them with a 2 pound rubber mallet.
It helps if you spray the hubs with some penetrating oil the day before.
Remember to clean the hubs before you reinstall and you may have to adjust the parking brakes for the new rotors by turning the star wheel a number of clicks.
Old Feb 13, 2006 | 07:45 PM
C4driver99's Avatar
C4driver99
Old Feb 13, 2006 | 08:06 PM
VA 98 VETTE's Avatar
VA 98 VETTE
Did mine this past weekend, also. Hopefully this don't happen to you.
http://forums.corvetteforum.com/show...496&forum_id=1
Old Feb 13, 2006 | 08:10 PM
bcseitz's Avatar
bcseitz
I guess I was lucky. I didn't even have to do that.
Old Feb 14, 2006 | 11:39 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
There is no reason to disconnect the ebrake cable. As long as the ebrake is not engaged, the rotor will come off.
Old Feb 16, 2006 | 05:01 PM
electra's Avatar
electra
Park your car on a LEVEL surface and leave the E-Brake OFF in the car and you won't have to touch it at the wheel. Piece of cake; in fact when I did mine I was baby-sitting my 4 year old neice so I let her do it for me to keep her out of trouble! I think you will have to TRY to screw up. Good Luck!
Old Feb 16, 2006 | 09:52 PM
Bounty Hunter 6's Avatar
Bounty Hunter 6
Yeah, just don't forget to re-engage the e-brake before you take the rear off jack stands!!!!! "Level" doesn't matter when you still have the front up in the air!! Of course, that is assuming you are putting the whole car up on jack stands, in which case you would obviously lower the back end first....
Life would be so much simpler if everyone had lifts!!
To Changing Rotors
