ET 215's. Help calculating my compression?
Old Feb 14, 2006 | 07:42 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
Default ET 215's. Help calculating my compression?
Hey guys, need some help. There have been no mill to the heads yet. I have .075 out of the hole using .045 cometics. I verified my clearance and I have alot on the intake and about .192 on the exhaust. What would my current CR be? If needed, how much could I mill and be safe without fly cutting. The cam is a monster and I can't believe I have this much clearance available. Thanks in advance!
Old Feb 14, 2006 | 07:50 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
Joe G, where you at?
Old Feb 14, 2006 | 08:33 PM
RoadRebel's Avatar
RoadRebel
Hi,
First did you really mean .0075" out of the hole with what pistons? Stock or aftermarket. If aftermarket what CC reliefs do they have?
What size combustion chambers did you get?
Phil
Old Feb 14, 2006 | 08:50 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
They are stock bore forged flat tops. And yes, .0075 out of the hole. My bad!
Old Feb 14, 2006 | 09:09 PM
kumar75150's Avatar
kumar75150
what cc are the heads currently? a 346 right?
Old Feb 14, 2006 | 10:37 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
yes, 347 and heads are 62cc.
Old Feb 14, 2006 | 11:13 PM
97 SC Cobra's Avatar
97 SC Cobra
I get 11.21. Someone should verify.
Old Feb 14, 2006 | 11:28 PM
kumar75150's Avatar
kumar75150
ya i got 11.17:1
kumar75150's Avatar
kumar75150
how big is the cam and whats the lsa? you can probably get away with more static compression
Old Feb 14, 2006 | 11:40 PM
97 SC Cobra
What about using a 0.040 cometic and not milling the heads? Doesn't milling reduce the flow slightly?
Old Feb 15, 2006 | 08:43 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Joe G, or me
Steve, I didn't know you were doing a forged bottom end also
Old Feb 15, 2006 | 09:05 AM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
Hey Joey, Yes YOU! And yes, I decided what the heck, it was a piece of cake to pull the motor with everything off so I just popped in some forged stuff.
Old Feb 15, 2006 | 10:04 AM
IFLUBYU's Avatar
IFLUBYU
Is there anyone from ETP on the forum to answer this? I really like the heads, but I also really like the support/response from guys like Tony Mamo at AFR. Might be the difference between which set of heads I eventually buy.
Keep us up to date on what you find out!
Old Feb 15, 2006 | 10:08 AM
97 SC Cobra
They are quite active on the other site as they are a supporting sponsor there. PM me if you don't know what I'm talking about. They are very quick to respond to any questions I have.
Old Feb 16, 2006 | 04:26 PM
IFLUBYU's Avatar
IFLUBYU
Thanks, that's good to know. I don't go over to the other site as much as I should, but at least I know they are there!
Old Feb 16, 2006 | 05:44 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
Hey guys, good luck with getting them to answer your requests or emails. I have sent both PM's and emails and none of them get answered. You would think they would be more than happy to assist one of their customers but hey, guess NOT!
Old Feb 16, 2006 | 10:44 PM
97 SC Cobra
Call em.
To ET 215's. Help calculating my compression?
