Fuel Filter Question?
Old Feb 14, 2006 | 06:03 PM
happa's Avatar
happa
Default Fuel Filter Question?
I was wondering about how many miles should you change the fuel filter? Thanks!
Old Feb 14, 2006 | 06:15 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
50,000 or less, IMHO
Old Feb 14, 2006 | 08:33 PM
coast7's Avatar
coast7
Manual for my '98 says to replace it ONLY if there is a fuel flow problem. I believe newer models have their fuel filters in the fuel tanks and are designed NOT to need replacing.
HTH
Old Feb 14, 2006 | 11:08 PM
zoomnz's Avatar
zoomnz
Does anybody know the location for a 2001?
thx
zoomnz
Old Feb 14, 2006 | 11:34 PM
rws.1's Avatar
rws.1
Drivers side, mounted above the exhaust system approximately at the joint of the muffler system to the H pipe.
You need to unbolt and drop the left muffler to get access.
Old Feb 15, 2006 | 06:16 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
"YES" with respect to the location. "NO" with respect to having to unbolt any part of the exhaust system. You need, however, a set of the fuel line release clips.
I changed mine last year, only because it was 4 years old. The car had only 10,000 miles on it at the time. The filter is around $35-40 for an AC replacement.
Old Feb 15, 2006 | 11:28 AM
zoomnz's Avatar
zoomnz
Quote: "You need, however, a set of the fuel line release clips."
Where can I get these clips? How much do they cost? thx
ZOOMNZ
Old Feb 15, 2006 | 11:31 AM
djengr's Avatar
djengr
ZOOMNZ
Saw some at Autozone for around $7. I am sure most autoparts stores have them.
Old Feb 15, 2006 | 12:18 PM
leadfoot4's Avatar
leadfoot4
Mine are the Lisle brand name.
To Fuel Filter Question?
