TCS Issues when raining
Old Feb 16, 2006 | 04:22 PM
diviniti's Avatar
diviniti
St. Jude Donor '05
Default TCS Issues when raining
Ok, I keep getting TCS codes thrown when its raining or very wet on the road. It does the whole "reduce engine power"yadda yadda thing. Never happens when its dry. I have the car up in the air and going over all of the wiring harness connections and so on, I have no friggin clue what could be getting wet to cause this issue. Anyone have any ideas?
Just to be more clear, it has nothing to do with the slickness of the road, the tires do not spin. It has to do with something getting wet.
Old Feb 17, 2006 | 02:42 AM
diviniti's Avatar
diviniti
St. Jude Donor '05
P1125 Accelerator Pedal Position (APP) System
P1286 Accelerator Pedal Position (APP) Sensor 3 Performance
C1278 TCS Temporarily Inhibited By PCM
BO-RFA C2121 C
These are the codes.
The last one I cannot find in the C5 DTC code list, so I have no clue what it is. But it has been there since I purchased the car, so I am pretty sure it isnt a problem.
The first two, I think have something to do with the Reduce Engine Power. Because as soon as the TCS code is thrown, those 2 pop up, causing the Check Engine Light to come on, and reduce engine speed.
Old Feb 19, 2006 | 12:04 AM
diviniti's Avatar
diviniti
St. Jude Donor '05
Nobody has any input?
Old Feb 19, 2006 | 05:35 AM
cliff_ford's Avatar
cliff_ford
C2121 Tire Pressure Monitoring System Programming Malfunction
Old Feb 19, 2006 | 08:46 AM
vette747's Avatar
vette747
I read one post last year and a guy had the similar problem. Even in car wash. It was the panel under the PCM that was not fitted properly. That was giving the opportunity to the water to get into the PCM TAC area.
Old Feb 19, 2006 | 09:34 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What year car is it? Can you clear the codes? Are they Current or History?
BC
Old Feb 19, 2006 | 05:02 PM
diviniti's Avatar
diviniti
St. Jude Donor '05
BC
Yes, I can clear the codes. It seems while it is still 'wet', I guess, the codes just keep getting thrown, and are current. But after letting the car sit for a few hours to dry off, I can turn the key on and the codes are History.
Old Feb 19, 2006 | 06:14 PM
Laguna Blu's Avatar
Laguna Blu
I can't seem to get much feedback from a similar issue as you can tell by the lack of responses. http://forums.corvetteforum.com/show...786&forum_id=1
Old Feb 19, 2006 | 09:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What year car is it???????
BC
Old Feb 19, 2006 | 10:04 PM
Laguna Blu's Avatar
Laguna Blu
I'm a 1999
Old Feb 19, 2006 | 10:43 PM
diviniti's Avatar
diviniti
St. Jude Donor '05
BC
98
Old Feb 19, 2006 | 10:44 PM
diviniti's Avatar
diviniti
St. Jude Donor '05
Ya, it seems are issues are different though.
To TCS Issues when raining
