Changing brake pads
Old Feb 17, 2006 | 11:18 PM
FASTENUF's Avatar
FASTENUF
Default Changing brake pads
Planning on changing my brake pads tomorrow.
Anything particular I need to know?
Will I need any specail tools?
I've seen that I might have trouble getting the calipar off,
and to use loctite when reinstalling them. Any other advice would be appreciated.
Old Feb 17, 2006 | 11:31 PM
corvette dave's Avatar
corvette dave
Very simple job. No special tools except something to push the pistons back in. You can use a big c-clamp, channel locks, or something similar.
Calipers are not hard to get off.
I have never used loctite on calipers. You might be referring to the caliper brackets. They can be hard to get off but they only need to be removed if you are removing the rotors.
Check the level of brake fluid in the reservoir so you don't overflow it when pushing the pistons in.
Now would be a good time to bleed and flush the brake fluid if it hasn't been done in a while.
Old Feb 28, 2006 | 06:26 PM
rkhegler's Avatar
rkhegler
Are the bolts on the callipers left or right thread?
Old Feb 28, 2006 | 06:58 PM
rkhegler's Avatar
rkhegler
Never mind, I got them off.
Old Feb 28, 2006 | 08:07 PM
AFBombdude's Avatar
AFBombdude
A can of stop squeal!
To Changing brake pads
