cooper is coming out with a zeon sport A/S this month 400 treadwear AA A specs 10/32 tread depth , that is a very good tire, the cooper zeon 2xs is a very good tire for dry pavment.
for more info call kevin at KO tire 847.439.6986
I know your not from the area but kevin will tell you all about the tires.
also try doing a search in the wheel/tire section
Your seriously going to put those cheap *** tires on a corvette?
Don't listen to him. If your not worried about running 130mph for continuious amounts of time they're great. I had a set on my 90 notch mustang and I loved them for everyday driving.
I run Zeon's on my Grand National. They are 245/17s front and 255/17s rear. They have been a great tire for driving with a cool tread pattern similar to my old firehawks. They are not very sticky at the dragstip but are a lot safer than running drag radials on the street. When I was running drag radials, if there was any moisture(including high humidity), it felt like driving on ice. The Coopers channel water better and have decent traction in the turns. I am not sure I would run them on my Z06 though. With all the available F1 tires I would spend the extra for a tested and true tire. Good luck on your decision.
also try doing a search in the wheel/tire sectrion
here's the new tire:
Cooper rolls out Zeon Sport A/S
March 2, 2006
Cooper Tire & Rubber Co. has unveiled the Cooper Zeon Sport A/S ultra-high performance tire.
"The Cooper Zeon Sport A/S gives drivers the dry performance of an ultra-high performance tire," say Cooper officials.
The tire is "specifically designed for serious drivers who demand dry road agility and performance in an ultra-high performance tire with the added convenience of suitability for driving during the winter months."
It contains a new, silica-enhanced tread compound molded into a directional tread design, plus circumferential and transverse grooves for water evacuation.
The W-rated Zeon Sport A/S comes in aspect ratios of 55-, 50-, 45-, and 40-series sizes, and fits 16- through 18-inch wheel diameters.
