replace clutch master cylinder?
Old Feb 19, 2006 | 11:48 AM
usnskeet21's Avatar
usnskeet21
Default replace clutch master cylinder?
How many people have replaced their clutch master cylinder? I think mine is giving up the ghost. When i am trying to change gears while driving it is starting to grind. I have an exedy twin disc clutch. the pressure plate bolts are tight and the slave moves when the peddle is depressed. My clutch fluid resevoir isnt low and i dont see any clutch fluid around the slave.. any thoughts ?
