Programming for bigger TC
Old Feb 19, 2006 | 02:31 PM
hightest's Avatar
hightest
Default Programming for bigger TC
Is there any programming required with a bigger converter to compensate for the added slippage?
I've heard a number of different responses, some say yes and some say no. If there is some programming required, what parameters would the settings be at with LS1 edit?
Any replies would be appreciated.
Old Feb 19, 2006 | 09:33 PM
Mitch C's Avatar
Mitch C
To minimize the slippage with a big T/C program your part throttle shift points to upshift at lower speeds and lockup in OD sooner (35-40 MPH).
Old Feb 19, 2006 | 11:30 PM
Face's Avatar
Face
It's not NEEDED, but I'd recommend it. I've drove my car after a converter swap before and after tuning and it made a nice difference. If you were to drive my car you'd know that I had a high stall, but would never think it's a 4400.
Old Feb 20, 2006 | 01:45 AM
hightest's Avatar
hightest
Thanks guys,
how much sooner should I set the upshifts? Would 5 or 10 mph be too much, or should it be a higher or lower amount based on the size of the converter?
Old Feb 20, 2006 | 04:42 AM
Mitch C's Avatar
Mitch C
Originally Posted by hightest
Thanks guys,
How much sooner depends on how loose your T/C is and the gear ratio you are running. You can't just go by the stall speed of the T/C, the design of the T/C is very important. A T/C can be designed to be loose or tight. A bigger gear ratio will also effect how loose a T/C will feel & perform. If I were unhappy with the loosenes of my T/C I would first lower my part throttle shift points by 5 MPH. If I was still unhappy I would go lower in 2 MPH intervals untill I got the results I liked best.
Old Feb 20, 2006 | 08:52 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
FWIW, I made more changes changes at lower TPS than at higher TPS. The idea was too make the converter less noticeable at lower throttle positions by upshifting quickly. This strategy works well with bigger gears, less so with smaller gears. It'll take a some fine tuning. You might be surprised at the difference small changes can have at lower speeds/TPS.
Old Feb 20, 2006 | 09:50 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Great thread, I am getting ready to get my YANK SS2600 installed and hen I am tuning it in (for more reasons than just the tc).
Old Feb 20, 2006 | 12:02 PM
BlownV6's Avatar
BlownV6
Your going to wish you went higher.
Had the same exact stall until i rode in a 3200 stalled car.
Old Feb 20, 2006 | 12:09 PM
Face's Avatar
Face
I hope that's a typo and he meant 3600. I didn't know Mike made a SS series that small, almost seems like a waste.
Old Feb 20, 2006 | 12:59 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Damn fingers... I meant a YANK SS"3"600.
Thanks, for fixing me.
To Programming for bigger TC
