Tranny won't shift at WOT
Old Feb 19, 2006 | 07:04 PM
Scooter1964's Avatar
Scooter1964
Default Tranny won't shift at WOT
Has anyone experienced this before? I think I read a post a while back related to this but can't find any info now.
My 01 auto shifts fine everywhere except WOT. I've messed with the shift rpms but it seems to be getting worse now. I want to shift around 6200 but even with shift revs backed up to 5200 it still hits the rev limiter at WOT which is set at 6650.
I have a custom tune set up in a predator and shift pressure is set at +15%. Shifts are very firm but it just doesn't want to change at WOT. I have installed a set of 3:42 gears and as yank 2800 stall but all this was accounted for by tuner or they say?? I do have a cam and headers and a few other bolt ons but nothing extreme. About 369HP NA.
I know someone will tell me I need a transmission and I agree, even in the process of buying one but just don't want to give up on the one that is in it until i know it is done. Plus I don't want to have the same problem with a built tranny if it is a tuning problem. Thanks in advance. Any help will be appreciated.
Old Feb 19, 2006 | 07:10 PM
Mike Mercury's Avatar
Mike Mercury
WOT A4 shifting is done by RPM & MPH.
Take your A4 C5 and place the tranny in "1". Run it up to redline and note the MPH.
Then set the WOT 1 to 2 shift MPH via your tuner to 2mph below the noted MPH value.
Then do this in "2" - and program the 2-3 shift 2 below that MPH... and so on.
This should get you close to an ideal setup; though further tweaking may be necessary
Old Feb 19, 2006 | 07:58 PM
Scooter1964
Thanks for the help. I did find something on here about that. It had a link to a table that you could type in the values and it would give you your shift mph for each gear. I did this and then input this into the tuner at 5 mph less for each shift point. Does it have to be that close to the actual shift time?? Also some of the info I found said it needed to meet both values mph as well as rpm. If this is so would the car not shift at the specified rpm as long as the mph was set lower than the speed at which you reach the desired rpm?? I will try this to see if it helps though. thanks again
Old Feb 19, 2006 | 08:10 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Is this it?http://www.xse.com/leres/bin/gearrat...mference=80.42
Old Feb 19, 2006 | 08:12 PM
willyfastz's Avatar
willyfastz
The shift points matching could be it, but when my A4 started acting up on the full throtal shifts it didn't live much longer.
Old Feb 19, 2006 | 08:39 PM
Scooter1964
That was the table I used.
Old Jun 16, 2014 | 07:37 PM
Luweegy's Avatar
Luweegy
Did you ever figure this out?
Old Jun 16, 2014 | 08:25 PM
helga203's Avatar
helga203
Wow, 8 years ago i hope he did.
To Tranny won't shift at WOT
