Battery issue?
Old Jun 11, 2014 | 10:06 PM
Dcollins3208's Avatar
Dcollins3208
Default Battery issue?
So when I first initially start my car, voltage on DIC shows 14.2. After car heats up, voltage will fluctuate between 12.8-13.2 on DIC (yes I know not the most accurate method of checking voltage) and the lights will dim at stoplights, all of them: headlights, tail lights, etc. I've cleaned all grounds, all connections are tight (battery, starter lugs, alternator, grounds, fuse box, etc), and no codes. I should mention that this only happens at stop lights, while cruising it maintains between 13.4 and 13.7. Is this a battery issue or something I have to just deal with? Just another observation, if I hold down "up" on the window controls it will drag the DIC voltage down to 12.0
Old Jun 11, 2014 | 11:43 PM
Dcollins3208
Thank you so much, will measure voltage tomorrow and if need be, deal with ignition switch this weekend which it sounds like it actually is
Old Jun 16, 2014 | 08:53 PM
Dcollins3208
Voltages are as follows
With car off:
DIC: 12.1
Battery: 12.77
Car on:
DIC: varies between 12.9-13.2
Battery: 13.86
Alternator: 14.06
It appears that it is indeed the ignition switch.
To Battery issue?
