Another pinging question
Old Feb 19, 2006 | 10:51 PM
DuffyN's Avatar
DuffyN
Default Another pinging question - RESOLVED THANKS!
Whipping down the freeway today at 80 mph I wanted to speed ahead to change lanes so I punched. Of course I took off like a rocket but there was some pinging.
This is an 04 automatic with 2.73 gear so the motor was probably working hard. (80 mph is about 1900 rpm). California gas.
Does anyone think this is a problem???? If so, solutions????
I don't like it - but I think it's okay.
Old Feb 19, 2006 | 11:26 PM
SLPRC5's Avatar
SLPRC5
I'm in CA also and use Chevron 91 octane. A ping can be caused by a number of things, including engine temps., another is the octane of gas you are using. Knock retard adjustment is another one.
Old Feb 20, 2006 | 01:05 AM
DuffyN's Avatar
DuffyN
Interesting. I forgot to mention. Chevron 91 octane is what I am running. I like the service guy at my local Chevy dealer. He's had a couple of vette's, show rods, etc. I'll ask him. I think it's okay.
Old Feb 20, 2006 | 02:58 AM
SLPRC5's Avatar
SLPRC5
Yes the C5 runs best on Chevron and you may need to add a bottle of Techron to your tank. It could be plugs also.
Rsty
Old Feb 20, 2006 | 05:00 AM
99FewteRC5's Avatar
99FewteRC5
no pinging on 91 unocal gas.....might want to try top engine cleaner?
Old Feb 20, 2006 | 09:53 AM
corvette Mark's Avatar
corvette Mark
Are you running the factory or aftermarket air box?
Old Feb 20, 2006 | 02:18 PM
SLPRC5's Avatar
SLPRC5
99Fewter and lawless99 also have good reasons for a ping.
Old Feb 20, 2006 | 07:02 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I never had any pinging on 91, even when I was stock!!
Old Feb 20, 2006 | 07:14 PM
DuffyN's Avatar
DuffyN
Hmm. Interesting question on the airbox. It is the factory airbox but I put a K & N filter in it. Their instructions sucked. I'm sorry I read them. They said to remove the air box and put a gasket in it. After screwing around I discovered the instructions don't work for pulling out my box so put everything back together and I did manage to put the gasket in with the box in place - only to discover that it then made the whole thing too thick to clamp down on the K & N!! Finally.. duh... I just put the K & N in. It looked to clamp down on it, so no leaks, but the K & N is much thinner then the stock.
I think I will just get a stock filter and try that little experiment again! I've "hit it" before and not noticed the pinging. I'm pretty sensitive to that. And with the other guys not getting it....
Thanks for all the help! This is an awesome forum!
Old Feb 20, 2006 | 07:17 PM
Rag-Top Rick's Avatar
Rag-Top Rick
If you are still running the stock platinum plugs, it may be your problem.
The pucks on the stock plugs retain a lot of heat which could be the source of your pinging. You can check with your budy at G.M., but I`d try running one of the popular iridium plugs and see if that cures your problem.
Rick
Old Feb 20, 2006 | 07:45 PM
DuffyN's Avatar
DuffyN
Yeeks. This gets complicated. While reading another post I read about a "computer relearn" procedure. Maybe this is needed for the new air filter that is thinner???? (the "mate up" portion is same thickness as the old filter but the overall thickness of the "filter part" is much thinner).
I think I'll try the computer relearn 1st - that's the cheapest. Is it really necessary for the minium 11 minute wait three times?
Also just remembered, better get a stock filter for those trips to the dealer. heh heh
Old Feb 21, 2006 | 12:25 AM
DuffyN's Avatar
DuffyN
Default Pinging Resolved
Thanks for all the input. Based on the discussion I thought, hell, maybe the computer will figure it out. Another thing is, I hadn't done any high speed driving since I put the new K & N in - except for the one incident I had noticed the pinging.
So, I just went for another drive and it's running great! No pinging. What a f'n rocket!!
I guess the computer must have readjusted air intake or something.
Man what a machine. I'm a vette man forever!
Thanks for all,
Duf
Old Feb 23, 2006 | 01:27 AM
99FewteRC5's Avatar
99FewteRC5
some drivers just baby the motor's too much...never get on it. I think you need to open her up a little just to blow all the trash....carbon that builds up from stop and go driving.
Old Feb 23, 2006 | 10:30 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Year of the car and mileage....????
demand and load on a 2:73 geared motor could cause momentary ping.
that is a cruising gear used for better mileage, not for get up and go.
plugs, contaminated gas, timing, engine coolant temp, oil temp, demand and load all play a part.
The reason I asked about year and mileage: on older cars with significant mileage, carbon build up can cause increased compression and pre-ignition, especially under load.
Old Feb 23, 2006 | 12:19 PM
aj98's Avatar
aj98
I use Amoco 93, RFG II formula (which is CA law compliant)
My 01 MN6 pings near the top of the torque curve, but it can be in any gear. From a dead stop/in 1st, it is usually accompanied by a cloud of smoke.
I've asked the dealer C-x specialist about it; if I recall correctly, he said it (is something to do with) the EGR system, and although he could tweak the computer to eliminate the ping/smoke at WOT or near WOT, there would be a noticable performance hit.
AJ
Old Feb 23, 2006 | 01:58 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
If you drive a lot of city miles and have not used the top engine cleaner (which you cannot buy in Cali) you could have knock for sure. I had audible knock with 93octane at one point before cleaning mine.
Old Feb 23, 2006 | 02:49 PM
YO-EL's Avatar
YO-EL
Most California guys add a bottle of TORCO, and no pinging.
To Another pinging question
Old Feb 23, 2006 | 04:56 PM
Dirty Howie's Avatar
Dirty Howie
You only need 1/4 of a can to a full tank and pinging will stop...at least for me it did
DH
Old Feb 23, 2006 | 09:46 PM
Evil-Twin's Avatar
Evil-Twin
In California you can use "Seafoam " top engine cleaner.. it is a viable second to GM's product. IT works..
Old Feb 23, 2006 | 10:49 PM
BQuicksilver
Are you sure that's sold in Cali? I don't think it is.
