Black soot on rear end
Old Feb 22, 2006 | 07:43 AM
Rhode Warrior's Avatar
Rhode Warrior
Originally Posted by VetteDrmr
How long are you driving your car on a given trip? With that much water coming out (and this is the season to see it), I'm wondering if you're driving your car long enough to get your hi-flow cats up to temp. If they're cold they won't do their job very well and you could start seeing that carbon sooting.
It would be interesting to see how bad it gets if you go run your car for 15 minutes or so, leave it running, wipe the rear off then go drive again. If the soot goes away then we can start aiming at the startup enrichment/cold cats scenario.
HTH, and have a good one,
Mike
I'm sure that has a lot to do with it.
Old Apr 20, 2006 | 07:39 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Did you get your problem solved yet? Which mods did you do before this happened? How about you Aloha?
Old Apr 20, 2006 | 12:17 PM
corvette Mark's Avatar
corvette Mark
How about some pics? Maybe if we see how bad it is that will help.
Old Apr 20, 2006 | 07:31 PM
RED99's Avatar
RED99
Originally Posted by RonJ
My 01 does the same.
I get 30mpg on the highway and don't use any oil.
I also don't worry about it ....
RonJ ...
My 99' gets a little inside the taillight area. It's just little specs of black. I think it's probably brake dust because I have never seen black smoke, and this is when it was bone stock.
Old Apr 20, 2006 | 09:02 PM
ooh yeah's Avatar
ooh yeah
Originally Posted by cbx1047cc
I'm not talking about a little brake dust. I mean 1/8" black spots. It's only on the rear and it's all over the exhaust tips as well. If I let it sit there and idle when I first start it, there will be a mess on the ground, wet and black like you put black paint in a pump bottle and sprayed it. I can see the water droplets coming out and they are black from picking up the carbon inside the pipes. Still think it's brake dust?
I have a 01 coupe that does the same thing. But I think mine only does it when I;ve been at higher RPMS.
Old Apr 20, 2006 | 11:06 PM
gpracer1's Avatar
gpracer1
My yellow 00 does the same. Has the Corsa cat back. Black soot crap all over the back when I get on it alot. Just did a dyno run at XMS and the A/F ratio was 12.5 at WOT. Im sure its just that.
Old Apr 21, 2006 | 12:27 AM
Blue85L98's Avatar
Blue85L98
Cruise-In III Veteran
Originally Posted by mkiv808
Must be running a little rich from that tune?
I'm the original owner and my 2003 coupe would get black soot all over the rear fascia...from the day it was driven off the lot.
Last year I added LG Pro LT headers, high flow cats, Borla stingers and had it dyno tuned at A & A Corvette Performance in Oxnard, CA....Charlie Tuner said it ws pig rich. I haven't seen the soot since before the tune. It still sucks a little dust & dirt now, but no soot.
My guess is you are still running rich after the tune.
-dave
