No more Sunoco Ultra 94 ????
Old Feb 21, 2006 | 05:16 PM
C5 Curmudgeon's Avatar
C5 Curmudgeon
Originally Posted by dpd
as of last week,94 was taken out here in nj.i always used 94,now ?????
Use Sunoco (or anyone else's) 93. You won't notice any difference, except your wallet will a bit heavier. And an added benefit may be less carbon in your combustion chamber.
I never could understand why people would pay an extra 10 cents a gallon for 1 additional octane point they didn't need. To me it's a self-inflicted Corvette tax.
Oh yeah, I forgot, Corvette neurosis.
Old Feb 21, 2006 | 06:26 PM
C5Jim's Avatar
C5Jim
It takes more oil to make (refine) high octane gasoline. With crude oil prices as high as they are, could this be a trend to decrease octane while charging around the same price as the higher octane it replaced?
Old Feb 21, 2006 | 06:45 PM
Heretic's Avatar
Heretic
Originally Posted by JH
Ditto for Colorado:
85 = Regular
87 = Mid-grade
91 = Premium
91 octane+5280ft altitude=94 octane
Old Feb 21, 2006 | 07:16 PM
corvette-pilot's Avatar
corvette-pilot
Originally Posted by C5Jim
I filled up my car yesterday at Sunoco and found that Ultra 94 is now Ultra 93.
Not only that, but they now have 2 mid grades, 89 and 91.
Is this happening just in Pa?
So ???
The car is designed to run on 91 isn't it, anything more is just a waist of money
Old Feb 22, 2006 | 04:51 PM
FKING1's Avatar
FKING1
Still available in Detroit area. Hope Sunoco doesn't drop it here, use it in my Vette & Cobra.
Fred
Old Feb 22, 2006 | 04:55 PM
FastCashDave's Avatar
FastCashDave
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
If they do away with my 94 I'm going to protest, you know sighs, banners set on there door step for days.
My Vette needs 94
Old Feb 22, 2006 | 05:19 PM
DoubleZ06's Avatar
DoubleZ06
I honestly think anyone would be hard pressed to feel the difference between 93 and 94. Higher octane is only beneficial for reducing detonation. Unless you are running a high compression engine, 93 is fine.
Old Feb 22, 2006 | 05:37 PM
C5 Curmudgeon
Originally Posted by FastCashDave
My Vette needs 94
Actually, it's probably better off without it.
Old Feb 22, 2006 | 10:14 PM
Rich Z's Avatar
Rich Z
Has anyone actually tested the different brands of gasoline? Back in my GTO days (early 70s) I did some informal testing of all the highest octane versions of every brand in my area. Shell and Exxon had good mileage but so-so performance. Amoco (I think that is what it was called back then) had good performance but lousy mileage. The only one that had good mileage and great pep was Sunoco 260. I may have tested other ones by I don't remember now.....
Unfortunately, Sunoco is kind of rate here in north Florida. But I tend to use the premium name gasolines at 93 octane and avoid the no-name brands.
Old Feb 23, 2006 | 08:58 AM
RoadRebel's Avatar
RoadRebel
There are significant gains to be had with Sunoco 94 or their 93 on an FI motor . Not only from the extra point, but the additivesin the fuel that gets them the extra point and how it respondes in an FI motor.
Phil
Old Feb 23, 2006 | 09:00 AM
RoadRebel's Avatar
RoadRebel
Get a clue, this is the Tech section, not the General section. A Significant amount of cars in this section have been tuned and optimized on sunoco 94. And, as people are finding out the 93 is not cutting it based on knock sensor response.
Phil
Old Feb 23, 2006 | 09:02 AM
corvette-pilot
The everyday Joe wont notice a thing and I bet your car wont either.
Old Feb 23, 2006 | 02:50 PM
  #33
C5 Curmudgeon
Phil
And for the other 98% of us, my statement is correct.
So, perhaps, you're the one who needs to get a clue.
Old Feb 23, 2006 | 06:08 PM
  #34
C5Jim's Avatar
C5Jim
In regards to high octane, the argument can go both ways. But if you take your car out on the track as I do, then octane counts. Engine coolant temps and oil temps rise, as that happens combustion chamber pressure increases, then knocking occurs. I would think at that point you'd wish you had an extra octane point.
For those non-believers, have you ever driven a car that has overheated in the summer or lost a fan belt, etc. As the engine got hotter, the knocking increased.
Loss of octane at the pump, whether it's needed or not, is not a good sign. Let's hope this is not a trend.
Old Feb 23, 2006 | 06:58 PM
  #35
Face's Avatar
Face
Phil
This isn't the waxer section.
Having access to 94 for the street was nice. As for the track, I add a few gallons of 100 and have noticed a MPH increase and E.T. decrease.
Old Feb 23, 2006 | 09:38 PM
  #36
mdhmi's Avatar
mdhmi
I think it's generally understood that people with slow cars don't need 94. Pewter cars, especially those with turbos, like the higher octane.
If 94 is dead I'll probably just run 93 + Torco or just straight 100.
Cheers,
Mark
Old Feb 23, 2006 | 10:02 PM
  #37
Phil-Z06's Avatar
Phil-Z06
No more in NJ....some stations still have some in there tanks but after its all gone no more refills!
To No more Sunoco Ultra 94 ????
Old Feb 23, 2006 | 11:03 PM
  #38
Z.06's Avatar
Z.06
Default Octane requirements
Originally Posted by mkiv808
From what I've heard, 94 is useless unless you're running higher-than-stock compression. Or FI.
Not true. I have a stock 2001 Z06 (OK, it has a Vortex inlet filter box) and it runs fine on 93 octane premium. But drive it on 91 octane premium in West Texas, New Mexico, Arizona, California (crap gas), Nevada, Utah, and Colorado and it pings like crazy. Two dealers have checked it out and it has been decarboned twice. The engine computer has been reflashed twice and the pinging on 91 octane has not diminished. She runs great on 93 octane, though.
Old Feb 24, 2006 | 01:39 AM
  #39
edensknight's Avatar
edensknight
I have to agree with you on the Crappy gas in Cali. It is just 91 octane ("Ping-tane") in these parts.
Old Feb 24, 2006 | 03:19 AM
  #40
mkiv808's Avatar
mkiv808
Well, I'm talking about the difference between 93 and 94, I do agree that 91 and 93 (especially in certain altitudes) can be very different.
