HUD Install on a 97
Old Feb 20, 2006 | 08:39 PM
Gitusum's Avatar
Gitusum
Default HUD Install on a 97
im wanting to install HUD on my 97 i need a list of all the parts needed to do the install.
thanx,
rikk
Old Feb 20, 2006 | 08:46 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
you will need :
HUD enabled cluster (99 or newer)
try to get one that already has the HUD controls on it, (that way you will also have the elusive 11 wire harness).
HUD projector
dash bezel for HUD projector.
I paid a little over $300.00 for everything to do mine.
Old Feb 20, 2006 | 08:51 PM
Gitusum's Avatar
Gitusum
i knew i needed the cluster hud projector and the controls on the dash but wanted to make sure i dont need any other wiring other than the wiring going from the dash to the projector and the controls.also ive heard that if you install HUD that you need to change the winshield is that true?
thanx again,
rikk
Old Feb 20, 2006 | 09:15 PM
byte_me's Avatar
byte_me
it will work fine with your stock windshield...this is on my list of "to do's" for the 97 as well...
Old Feb 20, 2006 | 10:26 PM
Gitusum's Avatar
Gitusum
my next question is would it be easier to buy a hud cut dash or cut mine and if i cut mine how hard is it to do?
thanx,
rikk
Old Feb 21, 2006 | 07:11 AM
byte_me's Avatar
byte_me
thanx,
rikk
Go here:
http://joshker99.home.comcast.net/hudinstall2.htm
Found this using the "search" above- HUD installs are discussed a lot on the forum - the search can usually bring the required result on things like this...as well as headers, intakes, tires etc...
Good luck!
Old Feb 21, 2006 | 07:36 AM
Gitusum's Avatar
Gitusum
awesome thanx alot i believe that will be everything i need far as info! i love this site it has the best info and the people here are the best!
Old Feb 21, 2006 | 07:38 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
thanx,
rikk
Cutting is not so bad.
Old Feb 21, 2006 | 07:39 AM
JeepTJ's Avatar
JeepTJ
After
Old Feb 21, 2006 | 09:22 AM
tt427pacecar's Avatar
tt427pacecar
Not true at all. My retrofitted HUD works very well with my pre-HUD 1998 windshield.
Old Feb 21, 2006 | 02:41 PM
BATM4N's Avatar
BATM4N
Default So much for the Chevy Dealer
who told me "It's impossible to add a HUD in a vette that was manufactured without it." I'll be all eyes and ears to see how this "impossible" dream works out.
Old Feb 21, 2006 | 02:49 PM
BATM4N's Avatar
BATM4N
Originally Posted by RPOZ4Z
you will need :
HUD projector
Where did you get everything at that price? I just went to http://joshker99.home.comcast.net/hudinstall2.htm and it says GM price is $1,100
Did you go to a wrecking yard?
Old Feb 21, 2006 | 07:51 PM
Mad_Maxxx's Avatar
Mad_Maxxx
Yes, the biggest wrecking yard of them all, it's called something like Ebot.....Eboy...no, EBAY!
Old Feb 21, 2006 | 10:55 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
I'll agree to saying C-5.. good luck installing a hud in a C-3
To HUD Install on a 97
