Had to get a new motor
Old Feb 21, 2006 | 02:58 PM
1-BAD-C5's Avatar
1-BAD-C5
Default Had to get a new motor
Mine went up the rings are fluttering really bad, so Forged shortblock her i come...(delivered tomorrow)
346 bored 10 over, Stock GM crank, Callies h beam rods, diamond pistons 2 cc valve relief, arp rod bolts and mains, along with this install is going tsp ms3 v.3 camshaft, ls2 timing set, ls6 ported oil pump, asp pulley msd wires stock heads comp 921 valve train, hardened 7.400 pushrods, ls2 90 throttle body, lsx fast 90 intake, ls7 clutch , ls2 flywheel, and soon to come prc ls6 heads, with a 150 dual nozzle dry nitrous kit.
What do you guys think?
Old Feb 21, 2006 | 03:35 PM
BATM4N's Avatar
BATM4N
Sounds like a winner How much is it going to end up costing you? Inquiring minds want to know
Old Feb 21, 2006 | 03:58 PM
1-BAD-C5's Avatar
1-BAD-C5
$2700 for the short block,.. the other stuffi bought awhile ago, probably around 2-3000, and $1,100 for install
Old Feb 21, 2006 | 05:55 PM
Rhode Warrior's Avatar
Rhode Warrior
Not bad considering the mods. It's not exactly stock.
Old Feb 21, 2006 | 09:23 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Sounds like some great mods there and having some juice should be fun
Old Feb 21, 2006 | 11:31 PM
BATM4N's Avatar
BATM4N
Default Go for it!!!
Considering what your getting for what your paying I would say that sounds like a pretty good deal. Without a good running engine all you have is a mean looking car that can't back it up
To Had to get a new motor
