Rubber mount for...
Old Feb 21, 2006 | 03:49 PM
71corv's Avatar
71corv
St. Jude Donor '08
Default Rubber mount for...
rear differential. Need to replace this piece on a 1999 FRC as one of the studs has been rung off. Has anyone done this and can provide any guidance? Do the differential and trans have to be separated and or the half shafts removed? This is the mount that appears to be rubber with 2 studs thru it that extends down thru the rear cross member. Thanks for any help on this.
Gene
Old Feb 21, 2006 | 04:47 PM
94legaleagle's Avatar
94legaleagle
should be able to drop the rear suspension cradle and replace this -
Dropping the rear cradle involves removing the 1/2 shafts (easy) and removing the shocks where they bolt to the frame -
do a search for CajunDude's homepage link and writeup for his installasion of the DTE brace, and you will find instructions for removing the cradle. Follow these, and its no problem.
Old Feb 21, 2006 | 05:19 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Check out this post by Mike Mecury another forum member, very detailed.
http://mikemercury.home.att.net/342.htm
Old Feb 21, 2006 | 08:52 PM
SpeedyZ's Avatar
SpeedyZ
Should be very easy, shouldn't have to remove anything else. My guess is less than an hour. There is two bolts on top into the diff housing, and the two coming down that you are already familiar with. Simply remove all the bolts and nuts then jack the rear diff up just a bit and the mount will come right out. Best I remember it takes less than an inch to get it out. I can snap a closeup photo of the mount on a M12 if you want to see one. Just let me know!
Old Feb 21, 2006 | 09:16 PM
71corv's Avatar
71corv
St. Jude Donor '08
A "BIG THANKS" to all of you for the info. I think I will try the method SpeedyZ has posted and see what happens. Again, thanks to all for the info.
Gene
Old Feb 22, 2006 | 08:03 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Ah yes..........this one
I haven't tried it yet, but I would try the mount removal 1st.........lowering the cradle will work for sure
Good luck Gene, I also PM'd Mike
Old Feb 22, 2006 | 09:26 PM
71corv's Avatar
71corv
St. Jude Donor '08
Hey Steve. That's the one. Mike and I put the new mount in this afternoon. Took about and hour. Didn't need to raise the rear that much to get the old one out and the new one in. Thanks for your help with this and we will see you and Julie at Waterside.
Gene
Old Feb 23, 2006 | 10:23 AM
Cruise-In V Veteran
NCM Ambassador
To Rubber mount for...
