The original battery in my 2001 vert lasted about 3 years. I replaced it with another AC Delco battery two years ago and it seems to be wanting to die.
Sears gives a 6 year warantee on die hards....
The battery in my '88 is now 6 years old and fires strong.
My '01 original battery only lasted 3 years....
Answer... there is no set life... it varies form battery to battery, driving pattern to driving pattern
Too many factors to pigeon-hole all batteries without qualifying. My OEM lasted for 57K. Replaced it with Optima red-top; curently have 90K on the car (2003 Z06) same battery. OEM (Delco) can leak acid on your PCM (not a good thing!). Buy a leak proof spiral-core replacement and enjoy! Good Luck
Two factors that effect battery life are heat and use. A battery in a high heat application/climate and or a battery that is constanly allowed to die and then is recharged will reduce its overall life. As a general rule, 3 to 4 years is normal -
How long should a battery last?
The OEM battery in my 01 lasted 4 years, which actually surprised me.
Over the last oh, 24 years and 6 cars I've owned, regardless of battery mfr or car, most batteries lasted about 2 years less than their rated life. That is, a 60 mo battery lasts 36mo, 72 lasts 48, etc.
Should last and will last are two different animals. Some people have good results with long life and others do not. Fortunately that's what warranties are for.
I've had the least expensive Walmart battery last over 4.5 years, but my OEM ACDelco in my 01 C5 is going on 5 years in June and is still very strong. This may well be the best battery I've ever owned.
