Expected HP loss??
Old Feb 22, 2006 | 07:57 PM
Fastbasser's Avatar
Fastbasser
Default Expected HP loss??
What would be the "expected power loss" (if any) if you changed from 10-30 oil to 20-50 oil? I would think a heavier weight oil would rob some hp.
I was wondering if there was some sort of a formula or if someone has personal experience on a dyno doing this.
Thanks in advance..
:drive:
Old Feb 22, 2006 | 10:20 PM
c5vette_dallas's Avatar
c5vette_dallas
i tried it on the dyno and it hurt my car by 17 hp and 19ft lbs of torque
Old Feb 22, 2006 | 10:24 PM
Shane_S's Avatar
Shane_S
wow, then by those calculations my LT1 was actually making 400rwtq Didn't know that the heavy oil made such a difference.
Shane
Old Feb 23, 2006 | 07:55 AM
Fastbasser's Avatar
Fastbasser
HMMMMMMMM I lost 10.. Was wondering if I was alone..
For the record, I switched to heavier oil toincrease oil pressure, not for testing.
Old Feb 23, 2006 | 10:00 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The car is designed to run with 5-30, 10 30 would be ok... anything beyond that and you are running the risk of engine failure.. if you have low oil pressure, you have mechanical damage.. increased oil viscosity could cause a dry startup, lack of lubrication to the top end... the bearing clearances were design with 0-30 viscosity. I would Not recommend doing this, and I will not argue the point.. this is just my educated input.
Old Feb 23, 2006 | 10:11 AM
VetteDrmr's Avatar
VetteDrmr
But that increased oil pressure is due only to the resistance of the oil running through the engine, not due to any increased delivery to the engine bearings.
IOW, I agree with ET's assessment. I would expect 20w-50 to only be needed in custom-built engines.
Also, to your original point, high viscosity oil can soak up a lot of hp.
HTH, and have a good one,
Mike
Old Feb 23, 2006 | 03:17 PM
Monks's Avatar
Monks
[QUOTE=
For the record, I switched to heavier oil toincrease oil pressure, not for testing.[/QUOTE]
So how did it effect your oil pressure?
Russ
Old Feb 23, 2006 | 03:27 PM
Monks's Avatar
Monks
I agree on a stock engine with stock clearances, but what about
modded shortblocks. The engine builder of my forged shortblock wanted
me to run 10-40 Dino oil for the first 1000 miles. Now it is time for
Synthetic oil and I was planning on using 10-30, or 10-40. My oil
pressure is on the lower side ( 25 at idle, 45 at 2Krpms) and I am
kind of concerned about using 30 weight at idle.
Thanks,
Russ
Old Feb 23, 2006 | 03:40 PM
binkysgarage's Avatar
binkysgarage
I've seen high milage Honda's that run heavier then recommended oil, the oil rings are all gummed up, but the bearings look great. Being a drag racer, my motors are set up a little loose and I run heavier oils. You can gain HP on dyno by running 1qt less oil.
Old Feb 23, 2006 | 04:24 PM
vetteaddic's Avatar
vetteaddic
If your bearing clearance loose 20/50 if tight 5/30
Old Feb 23, 2006 | 04:40 PM
AU N EGL's Avatar
AU N EGL
Thanks in advance..
:drive:
Why would you want to go to a 20-50 OIL ???
for the track / racing 15-w50 is as thick as you want to go for extreem heat of hard racing.
During the summer on the track I run 15-w50. takes for ever to warm up, but can take the consistant 250-260 oil temps for 30 min at a time.
and I think the cars run better with a bit thicker oil, but that is just my opnion. No data to support it
No real need for anything that thick.
Old Feb 23, 2006 | 04:45 PM
greg_nate's Avatar
greg_nate
My unscientific data also says the same thing about thicker oil. Lifter noise disappears. I go back to 5-30 and instantly lifter noise is back. It doesn't seem like the lighter weight oil can keep the lifters pumped up. Then again, I am running an aggressive cam, so this may have something to do with it.
Old Feb 23, 2006 | 10:58 PM
Fastbasser's Avatar
Fastbasser
Mine is a 427.. Accordind to the guy that did the shortblock, he did it to "racing clearances".. Not real happy but it does run well. .. A very streetable engine that can run in the 10s.
Still wish I had more oil presure though.
Old Feb 24, 2006 | 12:31 PM
VetteDrmr's Avatar
VetteDrmr
I'd ask him what "racing clearances" means. Some think it means real tight, others loose. If it's loose then I'd run the heavier oil. If it's tight then I'd go with 10w-30.
You might also get an oil analysis done to see what your wear metals are looking like. ET, chime in here, but I'd think that if you were running overly heavy oil weights you should see the bearing metal content being too high.
Mike
Old Feb 24, 2006 | 01:50 PM
Evil-Twin's Avatar
Evil-Twin
Racing clearances are always lose allowing for lower end rotation and recovery.... A higher more viscous oil is good in this application.
The problem I have is giving advice based on a relatively stock LS/X engine. Then after all hell breaks loose because someone is running a highly modified engine, and wants to equate my advice to their engine... It gets old real fast.
Clearances on an LS/X are tight requiring a light oil... for those thinking your Grandfathers technology. Back in the sixties GM produced several aluminum engine platforms. These engine were prone to head warp and the life expectancy was around 50/60,000 miles..
Today's aluminum alloy engines are designed with 200K in mind.... This has all been achieved through advanced engineering designs. Bearing clearances, metal alloys, plastic alloys,cooling and lubrication are giant leaps in engine longevity.
Fastbasser's Avatar
Fastbasser
Racing clearances to this guy meant loose. Like I said, the car runs good. When it comes time for a "rebuild" in the next year or 2, I'll have it done somewhere else.
He did offer to redo the motor. I decided to wait and have it done later. As most know, it's alot of work to take these motors out in a small garage.
Next time who knows what I will end up doing...... Let me dream,,,, 9.5 -1 pistons and a supercharger!!
Thanks to all those that gave some imput..
Old Feb 24, 2006 | 04:46 PM
Fastbasser's Avatar
Fastbasser
By the way, how would I go about having my oil checked/tested after the car comes out of storage? May be something to do just to see what my motors "life expectancy" is!!
Any info w/b appreciated.
Old Feb 25, 2006 | 05:26 PM
crmvette's Avatar
crmvette
Default oil
15-50is what weight Lingenfelted recommends with PRO-LONG as a additive
To Expected HP loss??
