Sorry I know this subject has been clubbed to death, But I am trying to find any tech threads W/pics on how the sims are installed while replacing the F45's with 04 Zo6 shocks.
I did a search but with no luck.
Thnx
What year is your car?? I might be able to tune it out of your car with my Tech 2. I'll check and see. If I can, just bring it by my dealership and I'll take care of it for you N/C..
98 coupe, what dealership?
Another question comes to mind, after the option is deleted from the BCM, are the shocks still functional for driving,meaning can I drive the vehicle normally after the reprogram until the new shocks are installed.
Thanx for the info, the Performance shop I go to can perform this task with the tech II.
My question is , what step should I take ,
Install the new shocks , then go have it deleted.(will the vehicle dive normally until the BCM code is removed)
Or have it deleted then install the new shocks
Reason I ask is if the shocks are disconnected before the BCM change am I to understand the vehicle will not go over 80mph, and codes will be flying all over, I have to drive maybe 20 miles on the freeway to get to my tuners location.
thnx
Put on your new shocks. Leave the position sensors connected. You'll get error messages C1712, C1717, C1722, C1727 and Service RTD Suspension message to reset on your DIC, but you should be able to drive your car. Not sure if it will limit you to 80mph, but if so, that's not too much trouble for a short time until you can get the Tech 2 thing taken care of.
Cheers
John
