Throttle Body Coolant Question??
Old Feb 23, 2006 | 12:47 PM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
Default Throttle Body Coolant Question??
When installing bypass kit, are most of you capping off ports on throttle body or leaving open? Sorry for dumb question.
Old Feb 23, 2006 | 01:13 PM
INTHERED's Avatar
INTHERED
It does not matter its all depends on how **** you are. Since I fall into
that catagory I actually removed the coolant tube from the TB so I
it did'nt bother me anymore.
Old Feb 23, 2006 | 01:27 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Just my 2 cents, if you live in a cold place, do not do it.
Old Feb 23, 2006 | 04:10 PM
Oldvetter's Avatar
Oldvetter
It is suppose to stop throttle icing, which supposely happened during development testing.
Old Feb 24, 2006 | 12:09 PM
TEXHAWK0's Avatar
TEXHAWK0
Why not just leave the system as it was designed since bypassing the throttle body will have practically no positive effect on engine performance?
Old Feb 24, 2006 | 02:35 PM
DPG's Avatar
DPG
St. Jude Donor '06
its either heated by the coolant or by the heat of the motor....just another mod i guess.
Old Feb 24, 2006 | 03:49 PM
DoubleZ06's Avatar
DoubleZ06
Postively no difference either way. Just leave it.
To Throttle Body Coolant Question??
