Rough Idle
Old Feb 26, 2006 | 09:19 AM
dmicelli's Avatar
dmicelli
Default Rough Idle
HI,
I'm a newbie 99 coupe owner with Corsa pipes, X-over, and black wing. Not sure if a rough idle is normal? Car runs great, no pops or anything just a little rough at idle.
Extended warranty expires in 2 months, anything else to check aside from the codes (no more codes after I put a new Optima battery in)!
Thanks,
Dan
Old Feb 26, 2006 | 09:37 AM
Rhode Warrior's Avatar
Rhode Warrior
Rough idle is not normal unless you have a big cam. The first thing I would check for is a vacuum leak, especially around the mass airflow sensor.
Old Feb 26, 2006 | 10:10 AM
jers98vet's Avatar
jers98vet
A dirty MAF will also cause poor and or rough idle.
Old Feb 26, 2006 | 12:06 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
yep...air leaks around the air bridge are common...unmetered air will cause a miss just like a bad wire or plug
Old Feb 26, 2006 | 12:12 PM
dmicelli's Avatar
dmicelli
Default rough idle
So aside from visual inspection how do I find air leaks?
Looks like electrical contact cleaner is reccomended as a cleaner with the MAF off the car.
Thanks for the help, the forum has taught me alot in the past month or so!
Dan
Old Feb 26, 2006 | 12:40 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I would try switching out the black wing with a stock air box... as we have found in the past some C5's dont run well with that installed. (Its been well documented on this forum)
VR
Old Feb 26, 2006 | 09:47 PM
Jake T's Avatar
Jake T
When I bought my '99 a few months ago I noticed a rough idle. Drove it for about a week. Read the forum suggestions. I ended up putting in a fresh load of fuel along with a bottle of STP injector cleaner. The idle problem was gone in less than 100 miles. Cost.....$2.50
To Rough Idle
