comp r lifters
Old Feb 27, 2006 | 07:32 PM
108C6's Avatar
108C6
Default comp r lifters
anyone using comp r lifters? if so do u need to change to adjustable rockers. got them just wondering about the rockers.
Old Feb 27, 2006 | 07:52 PM
vettenuts's Avatar
vettenuts
I am not using them, but have read enough about them. You need adjustable rockers to get the very tight preload tolerance required. Be warned, there have been many who have had them grenade in the motor and cause major damage. There are a lot of guys over on the LS1Tech board that this has happened to. I went with the Morel's instead.
Old Feb 27, 2006 | 08:16 PM
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
i had them before in my old heads/cam motor, and they seemed to work fine but, when i pulled the cam out, i noticed there was some damage on the cam from possibly puking a needle bearing or something
Old Feb 27, 2006 | 09:27 PM
108C6's Avatar
108C6
thanks i have heard they are hard to get the preload set. will use something else are ready pulling motor for rod noise don't no more trouble
Old Feb 27, 2006 | 09:41 PM
Face's Avatar
Face
You don't need adjustable rockers, I've been running them for 25,000+ miles without any problems.
Old Feb 28, 2006 | 02:27 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
You do not need adjustables, had mine for a year.
Old Feb 28, 2006 | 06:06 PM
vettenuts's Avatar
vettenuts
Not sure which Comp part # you guys are running, but per Comp for the 875-16 lifters:
"Pro Magnum Lifters must be installed with ADJUSTABLE rocker arms and preloaded to 0.002" - 0.004". Always set the preload with the engine warmed to normal operating temperatures to allow for thermal growth."
If you are running the Comp stock replacement lifters, 850-16, this is not required.
Old Feb 28, 2006 | 08:11 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Ive got 16k miles on my comp Rs with stock rockers and no issues! They must be preloaded properly or else it wont work. Thats why I left it to the pros!
Old Feb 28, 2006 | 08:24 PM
vettenuts's Avatar
vettenuts
There is no way you can maintain a 0.002" tolerance on preload with the stock rocker setup. You either have a deeper preload then Comp recommends or you are running the 850's.
Old Mar 1, 2006 | 06:19 AM
Shane_S's Avatar
Shane_S
I'll let you know my results. Getting a set of the lifters installed with my G5-X3 this weekend.
Shane
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
This talk of "grenading" has me a little concerned. I put a set of them in my daily driven Z-28 a couple of years ago (LT-1 engine). They have about 6-7000 miles on them at this point. So far, they've been OK, but I don't rev the snot out of it....
Old Mar 1, 2006 | 07:59 AM
Shane_S's Avatar
Shane_S
I had them in my LT1 and drove it like i stole it for 30k miles before selling the car. And it still ran just as good as the day the engine was dropped in it.
Shane
Old Mar 1, 2006 | 08:50 AM
leadfoot4's Avatar
leadfoot4
I just checked in over at LS-1.com. From what I gathered over there, at some point in time, Comp changed the clip that holds the plunger in. My interpretation is that they went from a "C clip to the regular wire clip, and problems ensued...
Old Mar 1, 2006 | 12:20 PM
vettenuts's Avatar
vettenuts
I still think that the 850's are being confused with the 875's. Do a quick google on the Comp R's and you will quickly find out that the stock rockers don't get along well with them at all due to the preload. There are numerous posts about this on LS1Tech, and even a lot where they have been correctly setup and still granaded. A lot of the tuners on LS1Tech won't use them anymore because of this.
Old Mar 1, 2006 | 02:36 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I would have to ask Andy @ A&A.
Old Mar 1, 2006 | 08:00 PM
108C6's Avatar
108C6
well guys i have a set for sale not going to chance it already pulling motor for rod noise what a job without a lift!!! hope to have it out soon not to bad only spent 5 hours so far should be out in about another 1.5 hours are less
Old Mar 4, 2006 | 09:35 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
really? Look at post #3.
http://forums.corvetteforum.com/show...759&forum_id=1
So your going to try to school LG and ECS because they probably installed 850s then huh? amazing!
Again, thats why I leave it to the "pros"
Old Mar 5, 2006 | 08:03 AM
vettenuts's Avatar
vettenuts
As obviously, you should
I don't see anything in post #3 on the lifter preload.
To comp r lifters
