Sometimes the brand of headers and size (1 3/4" or 1 7/8") make a difference.
I'm using Magnecore KV85 wires with 45 degree plug boots on my Kooks 1 3/4" headers. Plenty enough clearance for me. HTH
Take the factory heat shields and spin the spring out of them. Then the shields will slide right over the MSD 8.5's and bend the wires to the angle you want
Will the angled plug boots work better than the straight boots?
They are billed as being for header cars and do work fine, but actually I think that at least in my application (with 1 3/4" diameter header tubes), the Magnecore straight plug boots would have would have been fine too.
I have used their straight boot versions in the past (without headers) and was also able to re-use the factory metal heat shields and springs with them too. HTH
