Will this work (brake calipars)?
Old Mar 2, 2006 | 02:59 AM
FASTENUF's Avatar
FASTENUF
Default Will this work (brake calipars)?
I want to paint my calipars Pewter to match my car but no one seems to make a high temp color that is very close so.......if I prime my calipars with high temp primer, then paint them pewter(with regular paint) then use high temp clear do you think they will last.
Old Mar 2, 2006 | 03:06 AM
Shane_S's Avatar
Shane_S
Not sure, as an alternative you might try to see if one of the vendors has a color of powdercoating that closely matches pewter.
Shane
Old Mar 2, 2006 | 03:26 AM
FASTENUF's Avatar
FASTENUF
Yea, I looked into powder coating also but no such luck there either
Old Mar 2, 2006 | 09:42 AM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Mine were done 2 years ago with regular Home Depot bought Rustoleum in RED. No high temp paint and they still look great.
Old Mar 2, 2006 | 09:57 AM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
Mine too. Unless you are tracking your car and really working your brakes, regular paint is not a problem.
Old Mar 2, 2006 | 03:30 PM
ThePizzaC5's Avatar
ThePizzaC5
Your method of high temp first will work, too. Just get a few good coats of high temp before you put the final color on, and you'll be good to go.
Whatever you do, make sure you clear coat it, so it'll hold up against the elements.
To Will this work (brake calipars)?
