z06 vs c5 question
Old Mar 2, 2006 | 03:33 PM
2000whitec5's Avatar
2000whitec5
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
Default z06 vs c5 question
if i want to go from a stock c5 suspension to a z06 set up, what do i need to change other than the shocks and sway bars? .. what else is different. any sugestions as to what way to go ? i want the car to feel tighter and for drag racing launch better.
Old Mar 2, 2006 | 03:35 PM
balduran's Avatar
balduran
I'd recommend a Chassis Brace, like the one andy at a&a sells, to go along with the z06 shocks and swaybars. Also, you might look at getting all new suspension bushings from a forum vendor.
Old Mar 2, 2006 | 03:42 PM
VetteDrmr's Avatar
VetteDrmr
What are you wanting to do? Feel better on the road? Get involved in autocross or track days? Drag racing? Different answers based on what you want to do.
Want to help, just need a bit more info.
Have a good one,
Mike
Old Mar 2, 2006 | 03:47 PM
94legaleagle's Avatar
94legaleagle
ZO6 suspension consists of different (stiffer) front and rear leaf springs, different sway bars front and rear, and different shocks front and rear.
For the sway bars, unless you have updated your endlinks, you currently likely have plastic endlinks - you will need to order metal endlinks if your Z06 swaybars don't already have/come w/ them.
Also, you might want to order the poly sway bar bushings from Ecklers for the Front sway bars to eliminate squeaks associated w/ the front rubber sway bar bushings.
As for shocks, you want the the shocks from a 2004 ZO6 since those are the "desired" ZO6 shock upgrade -
I think that's about it - I'm hoping to install all the above this weekend on my '01.
Old Mar 2, 2006 | 04:10 PM
2000whitec5
thanks for the feedback... i am looking more for a better ride .. no autocross , but i do drag race. just wanted to upgrade
Old Mar 2, 2006 | 10:44 PM
LoneStarFRC's Avatar
LoneStarFRC
Unless you already have the 6 spd tranny, the Z06 (and all 6spds) come with a 3.42 differential gear and you'll need to consider that change as well. HTH
Old Mar 3, 2006 | 08:05 AM
VetteDrmr's Avatar
VetteDrmr
Better ride as in less body roll? Stiffer feel? Better cornering?
Less body roll: sway bars
Stiffer feel: shocks
Better cornering: tires
HTH, and have a good one,
Mike
To z06 vs c5 question
