Optima Red Top
Old Mar 3, 2006 | 10:36 AM
cliff_ford's Avatar
cliff_ford
Default Optima Red Top
Well you guys have frightened me into swapping the battery, which I only fitted in November, for an Optima Red Top.
Do you fit the dinky sponge jacket or allow it to show its six pack?
What’s the jacket for anyway?
Old Mar 3, 2006 | 10:56 AM
VolFan615's Avatar
VolFan615
Yellow C3/C5
St. Jude Donor '05-'06
Not sure what a dinky sponge jacket is. Mine didn't come with anything like that.
Old Mar 3, 2006 | 10:57 AM
cliff_ford's Avatar
cliff_ford
The jacket on the old Delco
Old Mar 3, 2006 | 09:51 PM
2KFRC5's Avatar
2KFRC5
Mine came with that dinky sponge jacket. When I changed my original 6yr old Delco, I did re-use it on the DieHard replacement. It's listed as an Insulator,Bat in the parts description. It's purpose, I don't know, but thought maybe it was there to help protect the other parts from spillage/leakage.
Old Mar 3, 2006 | 10:26 PM
RWVH's Avatar
RWVH
Probably to help soak up the leaking acid on the Delco
Old Mar 3, 2006 | 10:38 PM
Shane_S's Avatar
Shane_S
Maybe it's to help keep cold weather from killing the battery? I dunno, I didnt get anything like that. I switched to an Optima Red Top about a week or so ago.
Shane
Old Mar 4, 2006 | 08:36 AM
ram965's Avatar
ram965
Heading out today to buy my red top! When the battery is disconnected does it screw up any computer things? Other than the radio is there anything else that needs to be rest?
Old Mar 4, 2006 | 08:54 AM
cliff_ford's Avatar
cliff_ford
Only the clock, if a security code is not set in the radio.
Old Mar 4, 2006 | 09:00 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
It's suppost to protect the battery from engine heat. It's doubtfull it really does anything.
HollywoodFRC's Avatar
HollywoodFRC
Default Battery Insulator
From what I've read, the black battery jacket is supposed to keep the heat down on the battery (it get's hot under a Corvrtte hood). It is an insulator, not a battery acid collector although it's probably soaked if you have a leaking battery. The original one from DELCO will fit a 78 profile traditional battery, probabaly won't work on a '6 Pack' OPTIMA since the insulator is shaped to be used for a square sided battery.
To Optima Red Top
