Too many variables,- driver skill, temperature, spinning tires (most defineately), but best guess is mid to high 13's and anywhere from 108 to 115 MPH- at least that's what mine ran when it was stock.
After several thousand dollars spent and hours of runs, I now run a 12.3 at 111 MPH
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
when my 2000 a4 with 2:73's was stock i went 13:45 @106 need to dump 2:73s should be your first mod.. learn from my mistakes i spent money doing headers, exhaust intake mass air .. ect bust thing you can do is gears.. if its a daily driver get a set of 3:42's with a 3000 stall.. will cost you about 2500 to 3000 installed you will be in the mid to low 12's easy second tick up. if you dont drive it all the time and want to drag a little go 3:73's and a 3600 stall and a set of ddrag radials again i wish it was the first thing i ever did .
