Wheel and Tire Help Please
Old Mar 5, 2006 | 11:14 AM
slolane's Avatar
slolane
CI 7-8-9 Veteran
St. Jude Donor '07-'08 & '12
Default Wheel and Tire Help Please
I got my tires put on my new wheels fri I ask the guys to put the weights in the back of the wheels so you could not see them. This is what I got. I do not know much about this sort of thing but you can clearly see the weights. In your opinon could it have been done differently?
Thanks in advance
Old Mar 5, 2006 | 11:24 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
thats pretty much standard.....for placement....... although thats alot of damn weights
Old Mar 5, 2006 | 11:26 AM
pewter99's Avatar
pewter99
you can see mine as well but damn
Old Mar 5, 2006 | 11:55 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Kind of hard to conceal weights anywhere on that style of wheel.
What is the finish of the inner barrel? They do make chromed stick-on weights for just this reason.
Old Mar 5, 2006 | 12:13 PM
kdub1's Avatar
kdub1
yep, same wheels same weight placement. not nearly as noticeable on the car.
Old Mar 5, 2006 | 12:43 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
on both accounts
Old Mar 5, 2006 | 01:05 PM
9T3JIM's Avatar
9T3JIM
Are those 17" fronts, if so might not clear your calipers.
Old Mar 5, 2006 | 01:32 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Chrome Paint?
Mask off the area around the weight and try chrome paint. Not perfect but better than nothing.
Bob K
Old Mar 5, 2006 | 02:41 PM
slolane's Avatar
slolane
CI 7-8-9 Veteran
Ok, thanks guys I feel better about them now. You guys are the best
Old Mar 5, 2006 | 05:23 PM
kdub1's Avatar
kdub1
They'll clear. Not by much, but they do.
Old Mar 5, 2006 | 06:23 PM
tsts's Avatar
tsts
Default weights
Slolane,
There is a possible way to make this better, you sure have a lot of weight on that wheel, I don't know if the others are that bad. Call around your area and find a tire shop that has a Hunter Model 9600 "Road Force" balancer (not a 9500- make sure its a road force balancer) or search web for that balancer, the company usually list who has it installed and there is more info on this type of balance. This balancer is used to balance the tire to the wheel for the best position before the weights are applied, tire ON wheel are rotated so the heavy spots in the tire and the wheel are not together but cancelling each other out as much as possible. All this is done while spinning the tire/wheel while applying pressure (road force) to the set up to allow for any balance changes that may occur under simulated driving conditions (weight) on the car. Their are many of these machines around, it may save you a lot of weight. This can also be accomplished somewhat through trial & error by rotating the tire about an 1/8 or 1/4 turn for a complete rotation and note where the best balance is found before applying the weights, most shops don't want to fool around this way, its too much trouble (but you still would be without the road force effect). The road force balancer will also tell you if the tire or wheel is excessively out of balance to the point of being defective and/or returnable according to the mfg. standards. Your profile is not filled out and I cannot see what city your located in to help you any further if possible. Good luck.
Old Mar 5, 2006 | 06:34 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
When you put a tire on a wheel, and it needs that much weight, you take the tire off the wheel and check the wheel without the tire. if the bare wheel needs that much weight then there is a problem....
If the wheel is good then moving the tire 90 degrees on the wheel should help, a Good tire shop will do this instead of just piling on the weight. It's the difference between a guy making 8 dollars an hr and a pro making 18 an hour changing tires.
Ive seen many Non OEM replica wheels take alot of weight. Cheaper wheels have much less quality control.
Old Mar 5, 2006 | 06:39 PM
bcseitz's Avatar
bcseitz
That's crazy to have that big of a weight. Tire need's to be rotated and rebalanced!
To Wheel and Tire Help Please
