A/C driver side
Old Mar 5, 2006 | 08:41 PM
TBaird's Avatar
TBaird
Default A/C driver side
My 1998 driver side a/c doesn't get cold. Its like it's on the same temp all the time, 80 or so. Heat and air is the same. Passenger side works great. I have the dual climate control and its been replaced and a/c has been recharged by the dealer. They can't get it right and i'm tired of get soak with no result. Any help would be great . Thanks
Old Mar 5, 2006 | 09:15 PM
bobc997615's Avatar
bobc997615
Any HVAC codes set in the DIC?
Old Mar 6, 2006 | 09:51 AM
greg 6746's Avatar
greg 6746
i had the same problem on my 98 talked to tech at my dealer he said to unhook both battery cables and touch them together for 10 sec. and hook them back up and it worked. hope this works for you.
Old Mar 7, 2006 | 10:52 AM
vettcrazed's Avatar
vettcrazed
Default A/C problem
Just posted an A/C problem with the same thing but not cooling on the driver side. I think I'll try the battery cable trick and see if it works.
Old Mar 7, 2006 | 04:30 PM
EFI-4's Avatar
EFI-4
TTT for you.
I've got the same problem, too.
From what I've heard, you may have to recharge your Freon. That "may" solve the problem. Good luck, and please post up if you solve it.
Steve
Old Mar 7, 2006 | 05:59 PM
Dragon-Vette's Avatar
Dragon-Vette
Steve
Had the same problrm with my 98...put a can of 134a in and that solved my problem...hope this helps.
Old Mar 8, 2006 | 11:23 AM
corvette Mark's Avatar
corvette Mark
Don't forget to close your eyes and click your heels together 3 times while performing this repair. Sounds like low freon.
Old Mar 8, 2006 | 11:26 AM
RubberBill's Avatar
RubberBill
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Geez!! Wish I needed my AC!!!
To A/C driver side
