Tried searching with no luck, so... How do you tell an LS1 intake from a LS6 intake while it is bolted in place? I have seen pictures showing the difference on the bottom side but not from the top.
I read in a gen 3 smallblock book that u can shine a light and see the difference. So lighten up because I didnt realize that you knew it all or I wouldnt have tried to help!!!!!!!!!!!
He stated he already knew the difference on the bottom...
12561182...I think this is also an older casting number for the LS6 intake...
2001-2002 12561182(ls6 intake)
2002-2004 12573572(ls6 intake)
1997-2000 12556333(ls1 intake)
If the water coolant crossover line is there running underneath the engine (from front to rear), it is most likely a LS1. If there are water coolant plugs (two of them) at the rear of the engine, behind the manifold and only a single water coolant line up front (running crossways only), it is an LS6.
Bottom line: there is not enough room underneath an LS1 manifold for the water coolant line to run from front to back. Only if someone has taken the manifold off, cut grooves in the reinforcing ribs underneath the manifold, will a stock LS1 water coolant line set-up work. HTH
BTW, the number that is cast into the manifolds are not part numbers for the manifold. They are engineering or casting numbers only.
