Hello, I was looking at my fluids last night and noticed both my brakes and clutch fluid are very dark, are there any instructions on the internet for how to bleed the brakes/clutch for an 02? Also, is it wise to use the same brake fluid in the clutch, or should I use the GM clutch fluid?
Look up a set of speedbleeders for your car if you want to save time...you just replace your stock bleeders and then just pump your brakes and catch the fluid...no need to have help.
Dark fluid is bad..it should be clear....
The clutch is a pain from what I hear...difficult to get to. I would say you can remove the fluid from your reservior on the clutch and refill with clean fluid and it will help....
