During PDA event at Pocono's I had problems going in to fifth gear when I was in fourth at the read line ~138mph. The gear would not go in or it would take a long time to get it in. What could be the problem? Did you have this happen? :confused:
Re: Ripper problem (5th gear) at 140 mph (ElDiablo)
ElDiablo,
My guess is that the clutch is dragging instead of giving full disengagement from the flywheel/pressure plate surfaces.
Wish I had the definitive answer for ya. I don't. Have you changed the fluid and bled the hydraulic system? If not that may be worth a try.
I've wondered if the system doesn't collect a little moisture over time and when sufficiently heated, especially in the slave cylinder area, it vaporizes and gives the result you indicate. It may be a reach, but might be worth considering, especially if a fluid change and bleed improves the situation.
Then there is the ongoing inquirey about the restriction in the hose. I think MelloYellow has had a new hose made up, to help remedy this situation and is going to get back to us. Hope the slave clyinder doesn't have to be replaced.
If you find a solution, we'll all be interested in what you find.
Not necessarily a clutch issue. I had a Ripper in my 2000 Coupe and until it was fully broken in, 1-4 were the only gears readily accessible without a LOT of effort. When I replaced the 2000 with the 2001, I pulled the Ripper out and installed it in my 2001. Now I have no problems with getting 5th and 6th gear. I think you just need to use it more in those upper gears to allow it to fully seat. Just my $.02 :chevy
Hi there Adam,
You are probably experiencing a slow blocker ring engagement on the 5th syncronizer. Depending on the fluid used, the blocker ring could be hanging.
I have your VIN, and will research the issue.
Did you get your post card about the parts??c4c5
