Cammed Engine life
Old Mar 10, 2006 | 08:16 PM
Z06-Goose's Avatar
Z06-Goose
Originally Posted by WKMCD
Timing belt?????
He-he! you know what I meant. I'm just used to say timing belt as opposed to timing chain. We know it ain't a Honduh!
-Goose
Old Mar 10, 2006 | 09:30 PM
Dirty Howie's Avatar
Dirty Howie
I have the AFR 205 Heads with a mild 220/224@.581 114
Daily driven at about 75 miles a day. And tracked (road race) 10 times a year.
How often do you guys think I need to change springs. And I don't even know what springs are on there......came with from AFR
DH
Old Mar 10, 2006 | 09:34 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
do youself a favor, change your spring tomorrow !
Big cams gotta hurt the motor a little more than smaller cams
Old Mar 11, 2006 | 02:03 AM
silvervette02's Avatar
silvervette02
I've been looking at cams for a while and I am looking at going with a comp cams 224/228 .534/.537 on a 112 LSA or their 228/230 .571/.573 on a 112 LSA. Any thoughts on these or suggestions? I have full dynatech LT's/cats/X-Pipe and LS6 heads that will be going on at the same time. I want good mid-range torque/HP gains as well as a decent lope. Oh yea, QTP cutouts off headers as well so I want it to sound good. Thanks.
Old Mar 13, 2006 | 01:44 PM
FASST LN's Avatar
FASST LN
silvervette02, I would think you would get about 10 to 15-rwhp more by going with the .57x lift cam that you mentioned over your other choice.
Old Mar 13, 2006 | 03:13 PM
Michael A's Avatar
Michael A
If you think about it, if you use a cam with the same lift as stock, and same lobe ramp rate, but just more duration, there shouldn't be any impact on spring life. So I guess it depends on how you define big. Spring stress depends on total lift, and the rest of the parts, depend on lift rate (which increase acceleration and requires heavier springs).
Michael
