THERMOSTAT INSTALLATION
Old Aug 13, 2001 | 04:10 PM
BRIANS1999VETTE's Avatar
BRIANS1999VETTE
Default THERMOSTAT INSTALLATION
IS THERE AND BLEEDER SCREW OR ANYTHING THAT YOU HAVE TO DO AFTER YOU INSTALL A NEW THERMOSTAT,ON MY C-4 THERE WAS A BLEEDER SCREW, I WAS WONDERING IF THERE WAS ONE ON THE C-5
Old Aug 13, 2001 | 04:18 PM
carpe dm's Avatar
carpe dm
Default Re: THERMOSTAT INSTALLATION (BRIANS1999VETTE)
Not that I know; put it in, fill her up and go.....
Old Aug 13, 2001 | 06:58 PM
2kbluestreak's Avatar
2kbluestreak
Default Re: THERMOSTAT INSTALLATION (carpe dm)
There is a good little trick to bleed air from the coolant system that will allow more coolant to enter. Simply pull one of the hoses that heats up the throttle body and watch it as you add coolant. When it starts coming out, slip the hose back on. I've always found it difficult with GM cars, including a C4, to get half of the flush water out of the system. Whatever the listed coolant system capacity, you want to add half of this as antifreeze. On some cars, running the engine till the thermostat opens allows you to get some more in. Usually, when the radiator won't take any more, I add antifreeze that should go into the system to a dry overflow tank. After a couple days of driving, overflow coolant going back and forth seems to mix the antifreeze in.
Old Aug 13, 2001 | 09:40 PM
Jim Kramer's Avatar
Jim Kramer
Default Re: THERMOSTAT INSTALLATION (2kbluestreak)
The service manual has a specific procedure for getting the air out of the coolant system. I followed that procedure. I think my new thermostat also came with the detailed instructions.
To THERMOSTAT INSTALLATION
