Chips?
Old Mar 9, 2006 | 08:45 PM
TSC5's Avatar
TSC5
Default Chips?
Just purchased a 99 with 13K miles, have gone through the fluids, checked everything over, got the recalls done and now ready to work on a little HP increase. I'm looking at a new air system, Blackwing or Vararam but need some advice on other ways to boost the HP. Would a racing chip be worth the money and if so what kind? I really don't want to get into a new cam/heads if I don't have to. Just want about 40-50 HP increase.
Thanks for helping a newb!
Tim
Old Mar 9, 2006 | 09:28 PM
kdub1's Avatar
kdub1
Congrats on the new Vette purchase! I'm sure others will chime in here, but C5's don't have "chips" per sey like the older models. Re-tuning is done via an aftermarket programmer, i.e. DiabloSport Predator Vinci/Crane Tuner, Hypertech, Superchips, etc. Personally, I bought the Predator. It's really a matter of preference. There's lots of info (and opinions) on the forum about them. Just do a search on programmers, handhelds or the names and read up on them.
HTH!
k
Old Mar 9, 2006 | 09:32 PM
game on's Avatar
game on
Congrats on your purchase.
Your vette is not a chip car. The last chip vette was 1992-93, I think.
Your car has a programable computer, PCM. Software that is out there that makes minor changes to the PCM includes HP Tuner, LS1 Edit, Hypertech Power Programer.
The programs provided as noted above don't give much horsepower. Something you not likely feel.
They do however provide the following base changes:
1. Turns the cooling fans on sooner, say 180 degress vs 220. Cooler engines do generate a little more hp.
2. Automatic transmissions cars are provided with options to change shift points which feels good.
The air intake systems help a little, but will not give you a big increase in HP.
HP gains of 40-50 HP comes from mods such as long tube headers, cam bump, and then tuning.
My opinion, don't waste your money on bolt ons!
Also, mods generally speaking, do not add value to the car.
Old Mar 9, 2006 | 09:33 PM
tiojames's Avatar
tiojames
Default horse power
A set of long tubes, Xpipe, hi-flo cats, hi performance mufflers, a good intake, and a dyno tune could probably get you the HP you are looking for. Good luck with the new ride.
Old Mar 9, 2006 | 09:39 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
except the bolt on statement, I consider my Header/exhaust upgrade a bolt on. Good luck
Old Mar 9, 2006 | 09:40 PM
kdub1's Avatar
kdub1
with the above. 40-50 hp is gonna set you back $1500-$2000 or more depending on how you buy the parts (new or used) and whether or not you do the wrenching yourself. Welcome to the world of Vette modding.
To Chips?
