Decarbing
Old Mar 11, 2006 | 01:18 AM
Pizzano's Avatar
Pizzano
Default Decarbing
https://www.corvetteforum.com/techti...=212&TopicID=1
Is this article a pretty good way to decarb, seems easy enough, If anyone has done it this way, I presume the funnel they show is adding the decarb into the Hose going INTO the intake manifold correct.
thnx
Old Mar 11, 2006 | 01:39 AM
MrLeadFoot's Avatar
MrLeadFoot
Correct, and don't forget to keep the windows up and the top on, when you start it after letting it sit overnight. The pics in the thread you linked to are very misleading. Take a look at how much smoke you'll get upon starting it in these pics. Note that it gets WAY worse when you drive it.
Oh, yeah, and don't forget an IMMEDIATE oil change after the drive to blow all that crap out! Take GOOD luck ay my oil catch can for what can get in your oil!
http://forums.corvetteforum.com/show..._id=103&arch=1
Old Mar 11, 2006 | 02:00 AM
Pizzano's Avatar
Pizzano
Thanx, much appreciated, do you have any recent pics of how the filter you have installed looks.
thnx again
Old Mar 11, 2006 | 03:23 AM
mathia's Avatar
mathia
The GM Top Engine cleaner (or Sea Foam) is poured into the intake. Not the PCV hose! You remove the PCV hose from where it goes into the intake manifold just behind the throttle body and pour the cleaner into the intake with the motor running.
You need to regulate the rate you pour at so that you don't stall the car until you've got about 2/3 of a can in there. It will take quite a bit poured in suddenly to stall the car which is why the instructions on the can suggest you only put in 2/3 before you try to stall it. Some fear that all that cleaner dumped in might cause the engine to hydro lock and so just slowly pour the can in and turn off the engine. I've done it both ways and they both seem to work.
The cleaner get sucked into the intake and cleans oil and carbon from it as well as the cylinders as it gets sucked in. DO NOT pout it into the PCV hose. That's not going to clean anything, just dump the cleaner into the area under the valve covers or the area under the intake if you have the Z06 PCV system.
Old Mar 11, 2006 | 10:54 AM
MrLeadFoot's Avatar
MrLeadFoot
thnx again
Details:
Filter installed in reverse flow position traps oil better than normal flow position.
Bead of blue RTV sealer rings the inside bowl to help prevent oil creepage.
Veedle valve at bottom of filter removed. 1/4" brass adapter and ball valve screwed onto bottom of filter enables me to drain oil from bottom, instead of pouring the oil out like you normally would, and have the oil have to run over the RTV bead.
(Excuse the relay for 4-bulbs-on-with-hi-beams mod on the left of the catch-can/filter. I haven't figured out yet how to clean up all those labels I put on the wires without forgetting which wire is which.)
Old Mar 19, 2006 | 04:21 AM
Pizzano's Avatar
Pizzano
I notice the article for decarbing is from 2003, so is the stuff needed still called (Top Engine Cleaner from the GM dealer), if so any idea how much each can is, and the article says 2 cans poured in , is this correct, or is 1 can only needed.
I understand the oil needs to be changed afterwards, but does this affect fouling of the plugs at all, or is that of no concern, (I just changed them and really dont want to bend to do it again).
Also mentioned by Mrleadfoot, to have the top on and windows up,rightfully so, is there a oily residue that will emit out of the exhaust,possibly getting over the paint, or is this just for the fumes, and smoke.
Thanx again
Old Mar 19, 2006 | 10:24 AM
MrLeadFoot's Avatar
MrLeadFoot
I don't think the name has changed. I'm pretty sure that I used 2 cans for the suck-into-intake method, although when I previously used Seafoam instead, I only used 2/3 of the can.
Good question! I didn't do plugs afterwards, and have had no problems since doing the decarb. But, think about it, you're decarbing, which is designed to burn everything off the pistons, right? So, I imagine with works wonders to clean the plugs, too.
Just fumes, no residue.
Old Mar 19, 2006 | 12:15 PM
Pizzano's Avatar
Pizzano
Ya!, I kinda thought it would clean the plugs also, but I figured I'd ask anyways, due to the coating on the plugs.
Old Mar 20, 2006 | 09:41 PM
MagRed_00's Avatar
MagRed_00
Details:
Sorry to hijack. I had an ebay catch can and was not pleased with it so I just did your method with the compressor parts. It looks nice, but what is oil creepage?
Old Mar 20, 2006 | 10:33 PM
MrLeadFoot's Avatar
MrLeadFoot
Oil creepage is when the extracted oil crawls up the sides of the bowl. This could result in the oil getting out of the filter and into the intake. Now, I'm not sure this can happen, because I put the ring of RTV sealer inside the bowl when I first put the little filter on. Just make sure the bead is at least 1/2 way up the bowl, so the oil level never rises above it to begin with. Mine's sitting about 2/3 of the way up, if not 3/4.
Old Mar 21, 2006 | 07:10 PM
Dirty Howie's Avatar
Dirty Howie
I used Seafoam and changed the oil after driving it for about 15 miles. Then I had the plugs changed a few days later.
DH
To Decarbing
