ABS/Traction Control messages
Old Mar 14, 2006 | 10:10 AM
tommyhorn's Avatar
tommyhorn
Default ABS/Traction Control messages
I keep getting a message to Serivice ABS and Active handleing that comes up. It only comes up at random times and sometime the ABS is going off when normal braking. The thing is, it doesn't happen all the time and I've had it in the shop twice and it hasn't happened either time while they had it in there so they couldn't fix it. Has this happened to anyone else or does anyone know what sensor may be causing this?
Read the sticky on Electrical Problems and im going to try to do this first.
Old Mar 14, 2006 | 11:12 AM
FASST LN's Avatar
FASST LN
It will be easier for those on the board to diagnose your problem once they know the trouble codes your car is throwing.
I have a similar problem but have had no luck in tracking it down. Good luck!
Old Mar 14, 2006 | 11:13 AM
cliff_ford's Avatar
cliff_ford
Post the diognostic codes and someone will sort you out
Old Mar 14, 2006 | 11:54 AM
tommyhorn's Avatar
tommyhorn
After reading the sticky on the top of the forums, im going to try to clean all the grounds first to see if this helps with the problem.
Old Mar 14, 2006 | 07:26 PM
lloyd's Avatar
lloyd
Default Ebcm
Sounds like EBCM going bad - check your codes and let us know
Old Mar 15, 2006 | 08:55 AM
DeeGee's Avatar
DeeGee
I had a one off occurrence recently. It threw a C1214 code. The advice I got was that it could be an EBTCM or EBMV problem.
Old Mar 15, 2006 | 09:34 AM
tommyhorn's Avatar
tommyhorn
Ok im a noob, what does EBCM stand for and how do I find the codes?
Old Mar 15, 2006 | 09:54 AM
cliff_ford's Avatar
cliff_ford
-Electronic Brake Control Module
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button to turn off any warning messages
3) Press and hold "options" and
4) While holding "options", press "fuel" four times within a 10-Second period.
Initially, the on-board diagnostics go into the "automatic" mode, which shows each module's DTCs in a
pre-set sequence: (Page No. are for the GM Service Manual)
10 PCNI Powertrain Control Module page 6-357 - 6-361
28 TCS Traction Control system ABS on page 5-86
?? RTD Real Time damping page 3-136
40 BCM Body Control Module page 8-405 LTD Page 8-727
60 [PC instrument Pane! Cluster page 8-508
80 radio page 8-213
99 FIVAC Heater Vent-Air Conditioning page 1-118
A0 LDCM Left Door Control module page 8-904 to 8-951
Al RDCM Right Door Control Module page 8-904 to 8-951
AC SCM Seat Control module page 8-1064-8-1082
B0 RFA Remote Function Actuation page 8-676
For each module, all DTCs will be displayed. If none are present in a module, you will see "no more codes" on the ICP display.
There are two kinds of DTCs, "Current" and "History," designated with a letter suffix, "C" or "H". A current code indicates that the malfunction is present in the system whose module is displaying data. A history code indicates a problem existed in that module sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it is possible it's evidence of a previous problem. Now solved, that was not removed by clearing codes. More likely is that a history code indicates an intermittent malfunction.
"Intermittent" are the most challenging DTCs. An intermittent may have happened only once, may have happened more than once but is inconsistent in its appearance or may be happening on a regular basis but not at the time the IPC is displaying codes. History codes can also be caused by a current malfunction in a system that is not Operating at the time DTCs are displayed. An example is the rear window defogger, which doesn't operate until the BCM detects engine rpm. For history codes set by a system that does not operate with the key on and engine off, a special diagnostic tool called a "scan tester is necessary to properly diagnose the malfunction.
Once the IPC has displayed all 11 modules, the system goes into the manual mode, which allows selection of each module, using combinations of DIC buttons. The manual mode can also be entered at any time during the automatic sequence by pressing any button except "E/M". Once the IPC displays "manual diagnostics", you may select a particular module by pressing the options button to go forward or the "trip" button to go back. Once a system is selected and a DTC is displayed, if more than one are present; press "gages" To move forward or "fuel" to go back. To exit the diagnostic mode at any time, press E/M". If you want to erase or "clear" codes, press "reset". Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory.
To ABS/Traction Control messages
