Tire sensor nut torque?
Old Mar 14, 2006 | 05:11 PM
TomT's Avatar
TomT
Default Tire sensor nut torque?
Is there a torque specification for the nut that attaches the tire pressure sensor to the wheel? Or, is it just a snug fit?
Thanks in advance.
Old Mar 14, 2006 | 05:16 PM
vettenuts's Avatar
vettenuts
Per my 02 service manual, for domestic cars, the torque is 35 lb-in.
Old Mar 14, 2006 | 06:31 PM
TomT's Avatar
TomT
Thanks.
Old Mar 14, 2006 | 07:54 PM
Oldvetter's Avatar
Oldvetter
For my 1998 it is 106 in-lbs
Old Mar 14, 2006 | 09:16 PM
Silver98's Avatar
Silver98
Old Mar 14, 2006 | 09:22 PM
vettenuts's Avatar
vettenuts
According to my 02 service manual, the export version gets tightened to 106 lb-in. This may be year dependent or more specifically sensor type dependent.
Old Mar 15, 2006 | 07:08 AM
Oldvetter's Avatar
Oldvetter
It could be sensor type dependent, note 1997-2000 is Gen I sensors, 2001-2004 is GEN II sensors. GEN I have an o-ring seal and GEN II have a rubber gasket (like a washer). The rubber gasket probably does not take as much torque to seal. With GEN I you are probably bottoming out against the metal and providing a groove for the o-ring compression.
To Tire sensor nut torque?
