Problem With Dual Zone Climate Control
Old Mar 15, 2006 | 04:55 PM
75SHARK's Avatar
75SHARK
Default Problem With Dual Zone Climate Control
Hi,
When I have the A/C on in my '98, I get cold air from the driver's side and only warm air from the passenger side, despite the passenger side temperature **** being on cold. About the same time this developed, I hear intermittent "grunting" noises from somewhere behind the A/C control unit. Do you guys know what needs to be done to fix this problem? Is it a dealer repair or something fairly straightforward that I can fix myself? By the way, I just replaced my original A/C control unit with a rebuilt one for other reasons (the digital display went out). These problems developed before I did this so it must be something else. Thanks a lot!
Rob T.
Old Mar 15, 2006 | 05:34 PM
jcgordon's Avatar
jcgordon
Default A/C Fix
Disconnect your battery cable over night and connect it again the next morning. Make sure that you give it time to loose the memory in the radio station presets etc. Doing this sometimes helps to reboot the system.
Good luck
Old Mar 15, 2006 | 07:05 PM
bobc997615's Avatar
bobc997615
Check the DIC for codes. It may have set HVAC codes but will not display them unless prompted.
Old Mar 18, 2006 | 10:58 AM
75SHARK's Avatar
75SHARK
With regards to disconnecting the battery. I disconnected it for a day and a half and the radio still stores the preset stations. About how long do I need to let it sit for? If that doesn't work, I'll take it back to the dealer. They're getting to know me very well there! Thanks.
Rob
To Problem With Dual Zone Climate Control
